strip 383
#468082
09/14/09 05:12 PM
09/14/09 05:12 PM
Posts: 67 Hawaii
dirtycj5
Hawaii
i have a extra 383 i would like to build it up to play around at the track. i dont want to go stroker its going im my 66 coronet. the car is a 4 speed whit 3:55 in the rear its a 68 block with 906 heads what would be a good combo: pistons? flat top or dome? and what company? cam? i want a soild been looking at hughes cams but i dont know what i want lol. thanks!!!!
Re: strip 383
[Re: Brian Hafliger]
#468085
09/15/09 06:30 AM
09/15/09 06:30 AM
Posts: 67 Hawaii
dirtycj5
Hawaii
i have a extra 383 i would like to build it up to play around at the track. i dont want to go stroker its going im my 66 coronet. the car is a 4 speed whit 4:10 in the rear its a 68 block with 906 heads what would be a good combo: pistons? flat top or dome? and what company? cam? i want a soild been looking at hughes cams but i dont know what i want lol. thanks!!!!
Depends on what you are looking for (e.t.)? Are you going to use the 906 heads? No matter what you do, I would use a 5.13 gear min. and a 29.5 tire. Wind the piss out of it and it will run good.
I like RPM heads with some porting, about 12.5:1 and a cam like: 254-256@ .050 on a 105lca. 950HP carb, good intake and 1 3/4 min. headers should run very well.
ill be happy with 12's just wanna have fun at outlaw drags. i have a set of 5:13's in a 489 case but the sg is worn out (one tire fire). i kinda want to stick with the 906 heads i dont really have that much cash to dump in to this project. but it will be ported with those templates. i also have a set or arp head studs and main studs so even some n20 will be used
Re: strip 383
[Re: 440FISH]
#468086
09/15/09 06:33 AM
09/15/09 06:33 AM
Posts: 67 Hawaii
dirtycj5
Hawaii
I'm doing the same, I have a few extra parts lying around and a good 383 long block. So I'm putting it my car to see what it will do. I had almost all the part but the cam.
It is a 10:1(9.91:1 to be exact) 383 with milled and ported set of 452's with 2.19/1.81 valves.I just orders a cam for it from Porter Racing, solid lifter 251/256@.050" .560/.570 on a 106šlc. 1 3/4" headers with 3" pipe. 4500stall and 4.11's That is what I have, we will see how it runs...
could you pm me when you try this set up i would love to hear how it turns out
Re: strip 383
[Re: dirtycj5]
#468087
09/15/09 07:57 AM
09/15/09 07:57 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
turbos
Re: strip 383
[Re: dirtycj5]
#468089
09/15/09 03:56 PM
09/15/09 03:56 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
How heavy? If you don't know, how much are you stripping out of the car? 383's are weight and parts sensitive. The combo needs to be "matched" unlike a 440 where you can just throw stuff at it.
Re: strip 383
[Re: RemCharger]
#468090
09/15/09 08:46 PM
09/15/09 08:46 PM
Posts: 67 Hawaii
dirtycj5
Hawaii
the car is striped down just gonna have a roll bar and a pair of seats. fiberglass hood and maybe front fenders if i can find a set for the right price.
Re: strip 383
[Re: Defbob]
#468091
09/18/09 02:58 AM
09/18/09 02:58 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
turbos
I would intercool that otherwise your wasting potential power and If Im not mistaken possible detination
Re: strip 383
[Re: Defbob]
#468092
09/18/09 03:45 AM
09/18/09 03:45 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
turbos
Turbocharged BB Mopar... In a GM!!!
Re: strip 383
[Re: dirtycj5]
#468094
01/06/10 09:27 PM
01/06/10 09:27 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
With the 3.55's, get flat top pistons (KB 162), 906's with 85cc will net 9 to 1 compression, car weight 3600-3800 lbs, 650 DP, 1-7/8" primary headers or HP Manifolds w/2-1/2" Exhaust and crossover. Hughes cam kit HEH2328BL3 With 4.10's, (KB162 pistons), 906's cut to 78-80cc's will net close to 10 to 1. Car weight 3300-3500 lbs, 1-7/8" primary headers (36" long) with 3" by 12" collector extensions)into a 2-1/2" exhaust system w/2-1/2" crossover pipe. Carb size should be a 750DP. HEH4246BL3 Cam kit. I would "pocket port" and port match the heads. Use a good single plane intake (M-1, Torker) might be able to use the Eddy RPM (better low/ midrange power). These are hydraulic cams, the solids call into Hughes for application. May want to upgrade to HD (Six-Pack) Rocker Arms, or Adjustable Rocker Arms. Try a 50 - 100HP NOx Spray Kit, for a start. I would NOT go larger without fortifying the combo. Food For Thought. Hope it helps you. Good Luck !!
Re: strip 383
[Re: HYPER8oSoNic]
#468095
01/06/10 09:43 PM
01/06/10 09:43 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
First off ,are you going to run 1/4 or 1/8 mile? That will determine the rear gear ratio, and tire size that you can fit under that car. 513 gear with a short tire for 1/4 mile won't cut it. Also, do you want to buy race gas? if not stay with the stock pistons with the 906 heads.My old 383 ran mid 12's in the 1/4 with bone stock 906's a 525 lift solid lifter cam, 750 holley, edelbrock intake,4.89 gear-4-speed at 3550 lbs Shifted at 6,800
Re: strip 383
[Re: rowin4]
#468096
01/06/10 09:54 PM
01/06/10 09:54 PM
HYPER8oSoNic
Desert Tracker
100 percent, but direct the post to dirtycj5. I'm just offering advice on the combo. By the way, good times with that 383 of yours!!! I ran 12.9 - 13.0's with mine years ago. Thanks man.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: strip 383
[Re: dirtycj5]
#468098
01/06/10 11:23 PM
01/06/10 11:23 PM
HYPER8oSoNic
Desert Tracker
As Moparteacher said in his post 383's like to spin, my question to you is how fast you want to go? You can make great power with a 383 but you must answer 3 questions. How light is the car? What cam/converter combo you would use? (4 speeds max launch rpm). How much do you intend to spend? My previous post was based on what you have to work with (basic equipment). A street machine with strip capabilities. Moparteacher's post is more of a "race-tuned" strip machine (street racer). A very well thought out post. Many more to choose from.
