CSI Trans Shield question? #467574
09/14/09 12:34 AM
09/14/09 12:34 AM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I finally got the transmission put together, and Placed the CSI carbon Fiber shield over the transmission (727) and it looks like the band that wraps around the transmission will hit my shift linkage? Even with the spacer plate that came with the shield?
What I'm I doing wrong?
Re: CSI Trans Shield question? [Re: 451Mopar] #467575
09/14/09 03:51 AM
09/14/09 03:51 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
it's a close fit on mine too but there is enough clearence with my T/A shifter. what shifter do you have?
Re: CSI Trans Shield question? [Re: rebel] #467576
09/14/09 08:44 AM
09/14/09 08:44 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I have a Turbo Action shifter as well. It is a close fit but it works without interference.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: CSI Trans Shield question? [Re: 67HEMI] #467577
09/14/09 09:52 AM
09/14/09 09:52 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i made a L shaped bracket about 4 inches wide that sticks up just enough to give me a little more clearance
Re: CSI Trans Shield question? [Re: rebel] #467578
09/14/09 04:23 PM
09/14/09 04:23 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I have the stock '71 B-Body Slap-Stick so I am not using a reverse valve body.
I may split the CSI plate, and weld in a spacer so it sits further out. I will have to see how much room I have to work with once the trans is in the car.
Re: CSI Trans Shield question? [Re: 451Mopar] #467579
09/14/09 04:38 PM
09/14/09 04:38 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
If you modify it in anyway, the warranty is void and so is the SFI /Tech portion of it
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: CSI Trans Shield question? [Re: 451Mopar] #467580
09/14/09 10:01 PM
09/14/09 10:01 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I had the same problem with mine. I ran the strap under trans pan, but when I put strap through the bracket, I folded the strap in half, then installed a 1/4" bolt (with lock nut and washers) through the slot in the bracket, keeping the strap away from shifter lever & cable. After the strap came through the sloted bracket, I opened it back up to go through the buckle. Also used the large pin (?like a safety pin) to keep loose end of strap away from headers.
Re: CSI Trans Shield question? [Re: 451Mopar] #467581
09/15/09 09:34 AM
09/15/09 09:34 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I ended up not bothering to use their supplied bracket for extending the strap out from the pan rail. Instead, I just ran the strap around the linkage w/o over-tightening it so it doesn't interfere w/ the OEM Slap-Stik shifter linkage.
Re: CSI Trans Shield question? [Re: BradH] #467582
09/15/09 09:45 AM
09/15/09 09:45 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
i hate to say, but i know alot of people dont even use the strap, they just bolt the shield up and go.
Re: CSI Trans Shield question? [Re: rtstreet] #467583
09/15/09 01:19 PM
09/15/09 01:19 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
With the shield sandwiched between the trans and a stock steel floor the strap probably doesn't do much. If you have a thin aluminum floor use the strap! You could fail tech without the strap if you're required to have the shield.
Re: CSI Trans Shield question? [Re: @#$%&*!] #467584
09/15/09 03:49 PM
09/15/09 03:49 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I don't use my strap....it's rolled up out of the way....I don't see how the shield could go anywhere.
Re: CSI Trans Shield question? [Re: Quicksilver440] #467585
09/15/09 04:57 PM
09/15/09 04:57 PM
Aurora, Colorado
451Mopar Offline OP
451Mopar  Offline OP
Aurora, Colorado
I could get away with out the strap, as I can't go quicker than 11:50 anyhow (no roll bar), but I prefer to have the strap installed.
I bought the shield when I was running the stock transmission internals, and wanted some extra protection 'just in case', but the intake valve broke before I got the shield installed. The SFI cert is probbably close to being out of date too.
Re: CSI Trans Shield question? [Re: 451Mopar] #467586
09/15/09 08:29 PM
09/15/09 08:29 PM
Central Valley, CA.
Central Valley, CA.
They will never check the SFI cert date on the shield....but for like $25 they will recert the shield if you want.
Re: CSI Trans Shield question? [Re: Quicksilver440] #467587
02/27/13 05:40 PM
02/27/13 05:40 PM
Billings, MT
gtxwannabe Offline
gtxwannabe  Offline
Billings, MT
I just bought a CSI shield. I suppose I need to remove the transmission? Any easier way?
Re: CSI Trans Shield question? [Re: gtxwannabe] #467588
02/27/13 06:23 PM
02/27/13 06:23 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Nope.
Re: CSI Trans Shield question? [Re: gtxwannabe] #467589
02/27/13 06:41 PM
02/27/13 06:41 PM
NC
440Jim Offline
440Jim  Offline
NC
Unless they changed the design, you will need to cut off the 2 forward bosses on the outside of the transmission to clear the shield.
Re: CSI Trans Shield question? [Re: 440Jim] #467590
02/27/13 06:43 PM
02/27/13 06:43 PM
NC
440Jim Offline
440Jim  Offline
NC
other side, before trimming
Re: CSI Trans Shield question? [Re: gtxwannabe] #467591
02/27/13 08:21 PM
02/27/13 08:21 PM
still waiting on 684
K
Kiner Offline
Kiner  Offline
K
What car do u have?
My experience . 70 rr 440 727. first u need a 3/8 12pt universal socket. On me two bolts bottomed out. Had to cut off a 1/4".
I had the engine and kframe out. Had to bolt it up a few times it hits in a few spots. It was fun to say the least.
If I had to try to do it the car i would probably unbolt the engine and tilt it. good luck . my
The bolts that come with it are 3/8 12 pt. allen bolts dont even work.
Re: CSI Trans Shield question? [Re: Kiner] #467592
02/27/13 08:26 PM
02/27/13 08:26 PM
Guitar Jones Online laugh2
What car do u have?
My experience . 70 rr 440 727. first u need a 10mm 12pt universal socket. On me two bolts bottomed out. Had to cut off a 1/4".
The bolts that come with it are 10mm 12 pt. allen bolts dont even work.
Mine were 3/8 12 point heads, a little long though.
Re: CSI Trans Shield question? [Re: Guitar Jones] #467593
02/27/13 09:36 PM
02/27/13 09:36 PM
s e mich
ro23car Offline
ro23car  Offline
s e mich
should be 3/8 bolts iirc.
