Re: mopars clay city, ky.
[Re: max_maniac]
#467396
09/14/09 04:08 PM
09/14/09 04:08 PM
Posts: 388 Michigan
SD800
I was going to tow down there but I will just be getting back from a hunting trip and will be leaving the 12th for a show, not enough time, work sucks!!!!!!
You'll have plenty of time to sleep when your dead, let's go
[Re: moparbrown14]
#467397
09/14/09 10:26 PM
09/14/09 10:26 PM
Posts: 2,050 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
Just found out Arm Drop Live @ Bristol has been canceled, so looks like were going to make the 4 1/2 hour tow to Clay City. Went to Mopar Thunder @ Bristol last week, had a blast, except for the flat tire (slick w/ tube) just before burn out 1st round fri. Couldn't happen earlier in the day when you have time to fix it, but at least it didn't happen after the burn out. That would have left a mark (wall, fender, roof, ect.)
[Re: Dabee]
#467399
09/15/09 07:17 AM
09/15/09 07:17 AM
Posts: 1,371 Tallmadge, Ohio
Butch
Tallmadge, Ohio
I'm going but no car this time. I'm hitching a ride with Duster Dude and Chuck.
Glad to see you are going Russ. You should do very well.
Butch
'74 Duster 440 '04 Hemi Quad Cab Ram '06 Pacifica '78 MGB
