Page 11 of 19 1 2 9 10 11 12 13 18 19
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46721
05/15/08 02:16 AM
05/15/08 02:16 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
One of the many reasons why we luv ya DW...
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ebodyseast] #46722
05/15/08 08:31 AM
05/15/08 08:31 AM
Ah,keep up the warm fuzzies!
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! #46723
05/15/08 11:11 AM
05/15/08 11:11 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Hey dgt71 - say hi to your wife and my kids
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ebodyseast] #46724
05/15/08 02:53 PM
05/15/08 02:53 PM
About what I expected,ignorance is not a virtue! Oh,and by the way,there is quite a resembelance .They look just like you.
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46725
05/15/08 05:01 PM
05/15/08 05:01 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
Will ACC have two quality carpets? This new exact one and the non exact one they make now?
Will everyone who sells ACC start to get the new exact carpet, I just saw that JC Whitney carries the ACC carpet for the B-Bodies.
Who knows? The Shadow Knows! But he ain't on this fraking forum! "This restoration is a test,, It is ONLY a test, Had this been an actual Restoration I would have received instructions on what to do and where to get the MONEY!" -------------------------------
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: RapidRunner] #46726
05/16/08 12:32 PM
05/16/08 12:32 PM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
The carpets will be the same. They will not offer two distinct versions. I will be posting a picture of the packaging you get from our company to illustrate the differences in shipping configurations. Thanks!
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46727
05/16/08 12:51 PM
05/16/08 12:51 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Will the B-body carpet have the cutout in the heal pad for the gas pedal to be located in the correct position on the carpet?
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46728
05/16/08 01:14 PM
05/16/08 01:14 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do you have any idea as to shipping cost as per your packaging?
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: RoadRunnerJD] #46729
05/16/08 02:14 PM
05/16/08 02:14 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
What year B-body?
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: A12] #46730
05/16/08 05:50 PM
05/16/08 05:50 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I would assume he is refering to 68-70 style
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46731
05/16/08 05:56 PM
05/16/08 05:56 PM
Mass
charge70 Offline
charge70  Offline
Mass
Will you be at Mopar carlisle and will you be selling these carpets there.Thanks John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: charge70] #46732
05/16/08 06:16 PM
05/16/08 06:16 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
That was my next question
MikeE
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: RJS] #46733
05/16/08 06:40 PM
05/16/08 06:40 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Just trying to figure out if the '68 pedal (re: rubber carpet pad) was mounted in the same position (on the rubber pad) as the '69? This is a '69 so I would assume it is incorrect being mounted forward of the pad and through the carpet?
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: A12] #46734
05/16/08 06:43 PM
05/16/08 06:43 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is an original '69 GTX with the pedal on the rubber pad
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: A12] #46735
05/16/08 06:45 PM
05/16/08 06:45 PM
VA
RapidRunner Offline
RapidRunner  Offline
VA
Gee, where have I heard this discussion before
MikeE
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: RapidRunner] #46736
05/16/08 07:20 PM
05/16/08 07:20 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
MikeE
MikeE, scroll up to JD's post that went something like this;
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: A12] #46737
05/17/08 02:09 AM
05/17/08 02:09 AM
VA
RapidRunner Offline
RapidRunner  Offline
VA
MikeE
MikeR,
I was referring to the where does the gas pedal poke through at, carpet or rubber pad
MikeE
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: RoadRunnerJD] #46738
05/17/08 11:32 AM
05/17/08 11:32 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
Since the B Body carpets are the same for a few years, ACC will not cut any areas to make those "year" specific. Shipping costs depends on ZIP code but we are probably going to do a blanket (complete) cost that will be good for any city in the U.S. Since carpet is not our main product line, we will not be set up at any shows to distribute it. I am not sure if ACC will be able to bring this product to shows unless it is pre boxed in the small containers. It might be very difficult to keep the sets together if they do not already have them boxed. (Not to mention the additional space to be able to ship it in a flat/stacked manner.) On a separate note, I have spent the past two days trying to reference the "grommet" scenario. I am veering toward the opinion that not every car had this feature due to different suppliers of the carpet. I have found a few cars that did not have the clips in place to hold the carpet/grommets. My original Challenger was not even drilled to have the clip screwed into place. One car I found simply had a slot in the carpet (no grommet) that allowed it to be slipped over the unique clip. I will post all the photos of all the samples I documented after I get them downloaded. Hopefully this will shed some light on this subject! Thanks.
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: ECS] #46739
05/18/08 02:29 AM
05/18/08 02:29 AM
The Last Frontier
Alaska_A12 Offline
Alaska_A12  Offline
The Last Frontier
Dave,
You have always been fair to me so here is a tip. Alaska and Hawaii are part of the USA but shipping is not generally friendly to us. You might want to alter your offer to read "Continental US".
______________________________________________ http://regcars.homestead.com/car107.html
Re: FINALLY! FACTORY EXACT AUTO CARPET!!! [Re: Alaska_A12] #46740
05/19/08 11:55 AM
05/19/08 11:55 AM
USA
E
ECS Offline OP
David Walden
ECS  Offline OP
David Walden
E
USA
We will do everything necessary to make sure that all customers are treated in a similar and fair fashion.
Here are some findings with the variations on the carpeting. Notice the difference in the jute padding that was in this car. The tags read for a "Barracuda" but were in a Challenger! The vendor is also different from the J.P. Stevens style that is predominately found in E Body vehicles. There is a slot in the carpet instead of a brass grommet. I have not found an E Body with the brass grommet in the carpet as of yet. While talking with Bill Embree, he stated that the attaching feature was only to hold the carpet in place while the workers did their interior assembly jobs. Once the interior was installed, the clips and slots had served their purpose to hold the carpet in place. This was more of an assembly feature incorporated to keep employees from kicking the carpet out of place before it could be permanently positioned. Here are the pictures showing some of these features.
