The results will be that you will go down the track further in 1st and 2nd gear before going into high, which means the motor will cross the finish line at a lower RPM ,possibly
I say possibly because your motor may be cammed to pull real hard above 6000 rpm unlike a motor that is designed and cammed to pull hard from 4000 RPM to 6000 RPM. What size motor and what are the cam specs and intake lobe center with the lobe seperartion angle? What I have found on Mopar motors is the smaller C.I. motors need more rear gear ratio than the larger C.I. motors do, even in the same family of motors, BB vs SB
My Duster ran the same ET (10;40s)and MPH (128.+)with 3:73, 3:91 and 4:10 gears, the electric fuel pump was the problem in the end
