wiring for heater fan #466735
09/12/09 11:18 PM
09/12/09 11:18 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
got everything ordered to start on my wiring/custom dash project and figure i should probably keep a heater in the car for fall and spring driving in IA.
so, would it be possible to run a 4 position switch to control the fan speed for the heater? my valve has never worked, so i've been using a manual valve under the hood.
i really don't want to use the stock panel and i'm trying to get rid of all that factory clutter.
thanks
'71 Satellite Sebring 440
Re: wiring for heater fan [Re: landon1] #466736
09/12/09 11:42 PM
09/12/09 11:42 PM
rather than a multi position sw feeding fire to stock type resistors I think I'd use a variable speed switch. Your wipers slow down with the reduced voltage at idle & I think a variable resistor rheostat type switch would do the same thing & maybe work better for you
Re: wiring for heater fan [Re: RapidRobert] #466737
09/12/09 11:46 PM
09/12/09 11:46 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
something like this? probably need something a bit more heavy-duty, though i imagine?
http://www.etech4sale.com/122158/radio-shack-25-ohm-rheostat-variable.html
found this one...25 ohm 25 watt 1 amp - not sure if that's enough either - maybe it is?
http://skycraftsurplus.com/index.asp?PageAction=VIEWPROD&ProdID=2007
Re: wiring for heater fan [Re: landon1] #466738
09/12/09 11:58 PM
09/12/09 11:58 PM
I'd find out how many amps the blower motor draws (maybe use your VOM on amps in series on the hot wire) & we know the volts (12). That ought to be enough for an electronics tech to recommend one
Re: wiring for heater fan [Re: RapidRobert] #466739
09/13/09 12:02 AM
09/13/09 12:02 AM
IA
landon1 Offline OP
landon1  Offline OP
IA
or i just found this lil switch - not sure if it's resistor based or not, but it's actually made for automotive heaters.
http://azcustomcars.com/product.php?productid=107198
Re: wiring for heater fan [Re: landon1] #466740
09/13/09 12:13 AM
09/13/09 12:13 AM
I used a variable speed wiper motor in a 65 dart & if I cant locate a variable speed switch maybe one of those will work for me.
