Anyone Tow w/ a 3/4 Ton Van? #466667
09/12/09 09:47 PM
09/12/09 09:47 PM
Morrow, OH
markz528 Online content OP
markz528  Online Content OP
Morrow, OH
I am considering trading my 1/2 ton pickup for a 3/4 ton van.
Anyone tow with a 3/4 ton van? If so, how does it tow? What kind is it and what does it get for fuel economy towing and unloaded?
I tow an open trailer - - with car weighs about 5500 lbs.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466668
09/12/09 09:59 PM
09/12/09 09:59 PM
Bristol, Va
fasteddie Offline
fasteddie  Offline
Bristol, Va
I tow with an 89 3/4 ton Dodge van. It has the 318 with the 999 trans with the low gear set and lock up convertor. Rear gear is a 2.76. I tow an open trailer and the Dart. About the same weight as you.
It tows fine. I towed to Gainesville Fla a few years ago for the division 2 finals with no problems.
I've had the van for 12 years. We used it for a carpet cleaning truck with about 1000 lbs. of equipment in it for 10 years.
The only trouble I've had is a leaky front seal, and the convertor quit locking up. I had the trans rebuilt while it was out to fix the leaky seal and replaced the convertor.
It's a good van. I used it today to tow to Bristol Dragway and I won the King of the Strip 12.00 index class.
Edit: Don't know about fuel usage now. I haven't done the math since the rebuild and new convertor. On the Gainsville trip with the convertor not locking up it got about 13 mpg. It should be better now with the lock up.
Edit again. It does have load helper springs on the rear shocks.
2003 Bristol Dragway Sportsman Champion
2016 Bristol Dragway Power Hour Champion
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466669
09/12/09 10:00 PM
09/12/09 10:00 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Lent my pace inclosed 28 footer to a friend with a ford 3/4 ton regular wheel base van. It pulled it ok but even with the load levelers it sank the back down. I would never tow with those long over hung models. You shouldn't have a problem with a open trailer with that weight.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: rowin4] #466670
09/12/09 11:13 PM
09/12/09 11:13 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Yep...first with dodge service type van with 360. That got lost in a flood with the open trailer on back and the 65 coronet. Had water up to the carb.
then with ford 3/4 van for a while..... open trailers. No issues.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466671
09/13/09 11:05 AM
09/13/09 11:05 AM
NC
440Jim Offline
440Jim  Offline
NC
I towed my open trailer and car for years with an old 1994 Dodge B350 with the 5.9L (360) Magnum engine, A518 overdrive trans, 4.10 gear. I was very happy with it and got 12 mpg towing. I finally sold it with 215,000 miles on it.
This year I am using a 2005 Ford E350 with the 5.4L engine and 3.73 gears. I haven't done any long trips towing, and to my local track it gets about the same 12 mpg. Empty, with no trailer and 55 mph it can get up to 17 mpg.
Don't waste your time with any Ford truck with the little 4.6L V8. Not for towing. But the 1-ton (E350) comes standard with the 5.4. It was optional in the 3/4 ton (E250).
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466672
09/13/09 11:32 AM
09/13/09 11:32 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have never towed with a van but considered it years ago.
I think it would be safe to say that it would be way better than the 1500 truck, what motor?
Like others have said, I think it would a good upgrade from your truck depending on the drivetrain.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466673
09/13/09 11:36 AM
09/13/09 11:36 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I tow with a 86 B350 van, replaced the 360 with a rebuilt 400....it works great! I can load all sorts of stuff inside and still tow the car like it wasn't even there...not to mention you can sleep comfortably inside...I love my van...
71 440-6 4spd & 69 Hemi 4spd
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466674
09/13/09 01:38 PM
09/13/09 01:38 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I have a 97 E350 with a 7.3 TD, extended WB.
Its great. I actually like it more that the truck jsut because the cargo capacity is more useful.
8.30's @3400 lbs
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: Mike Swann] #466675
09/14/09 05:46 PM
09/14/09 05:46 PM
IL
furious70 Offline
furious70  Offline
IL
We towed for many years with a 91 E150 conversion, 351w, 4.10's, and basically a 3/4 ton spring pack, class IV with bars. Pulled a 70 mustang in a 20' enclosed. It was enough, but never impressive. Got about 8-10mpg. A club wagon with a 460 back then would have been a much better choice.
When we traded for a 26' enclosed and started towing a charger or coronet, the van was outmatched. Switched to crew cab duallies, then to cummins trucks. Will never switch back to gas for towing.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: furious70] #466676
09/14/09 07:23 PM
09/14/09 07:23 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
We use E 350 vans with 7.3s for work, with the right hitch they tow as well as my F 350 dually
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: emarine01] #466677
09/29/09 12:05 PM
09/29/09 12:05 PM
Morrow, OH
Morrow, OH
Well I hope I didn't make a mistake.
I bought a 2004 Ford E250 with a 5.4L engine. 95,000 miles. Power windows, power door locks and more importantly cruise control. Its officially a cargo van, but has a lot of passenger van features including cloth seats and full headliner.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466678
09/29/09 12:25 PM
09/29/09 12:25 PM
Q
qkRick Offline
qkRick  Offline
Q
My Towed thousands of mi.with 3/4 ton Chevy mini camper with 350/350 combo pulling approx 5K with 3:54 or 55? gear. 1 trans rebuild at 55K even with monster cooler. I like towing with a van due to shorter front = greater maneuverability in tight spaces.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466679
09/29/09 01:41 PM
09/29/09 01:41 PM
Cincinnati, Ohio
Cincinnati, Ohio
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: Challenger 1] #466680
09/29/09 07:45 PM
09/29/09 07:45 PM
i towed with a Ford E350 diesel extended van. i pulled a 24 foot haulmark enclosed trailer, and all i can say is what a mistake. i blew the high pressure oil lines off on the GW bridge, ruined a tranny, the crank trigger broke, front end needed to be rebuilt 3 times,rear springs were shot fast.
the pickup is the only way to go imo.
ill never tow with a van again.
Re: Anyone Tow w/ a 3/4 Ton Van? #466681
09/29/09 08:02 PM
09/29/09 08:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
He's pulling a open trailer not some over weight cheapass haulmark trailer.
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: Challenger 1] #466682
10/01/09 07:42 PM
10/01/09 07:42 PM
Morrow, OH
Morrow, OH
Well she's home.........
Re: Anyone Tow w/ a 3/4 Ton Van? [Re: markz528] #466683
10/01/09 07:44 PM
10/01/09 07:44 PM
goodluck with the van. i hope the converter holds up.pickup would be my choice.
Re: Anyone Tow w/ a 3/4 Ton Van? #466684
10/02/09 07:28 AM
10/02/09 07:28 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I guess being a Ford had nothing to do with it...
