Help needed updating a 426 hemi with a roller cam
#466292
09/12/09 11:35 AM
09/12/09 11:35 AM
Posts: 123 usa
DLP4
usa
I'm interested in installing a roller cam in a street only hemi car but I'm having trouble finding all the info I need to do what I want. Does anybody make a "tame" solid roller cam for a street driven hemi? Do I need a bronze intermediate gear if I can find a street cam? Or do I always need bronze? How do I install a cam button? (The shim is probably self-explanitory but I should ask about installing that too.) I had a Comp Cams 557/540 that I was happy with until the lobes went away. Something in that performance range or even a little less would be good. thanks
Re: Help needed updating a 426 hemi with a roller cam
[Re: DLP4]
#466293
09/12/09 11:56 AM
09/12/09 11:56 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
I've never seen a "tame" roller for a Hemi, I have a couple of the "smaller" ones that are available, and they are still around .650 lift and are pretty long on duration. I doubt if there is one available....I don't see the market for one.
You will need the bronze gear if it is a billet cam (most rollers are).
I still use the same old Crane cam button I've used for many years....I just tap it into the front of the camshaft in between the three bolts.
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
Post deleted by Defbob
[Re: DLP4]
#466294
09/12/09 12:01 PM
09/12/09 12:01 PM
#466295
09/12/09 12:15 PM
09/12/09 12:15 PM
Posts: 3,504 DFW
mr_340
DFW
Crane had a few Street Roller cams for the Hemi on their website before going under. I don't know if the resurfaced company still makes cams for cars.
Floyd Lippencott IV
[Re: mr_340]
#466296
09/12/09 12:23 PM
09/12/09 12:23 PM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
Check into pushrod oiling too when buying lifters. Some of us use cams with a little more lift and were gauling pushrods. It can be an issue, its not always an issue, but I believe you need oil through lifters to do it, so why not get those either way.
[Re: Dragula]
#466299
09/12/09 01:55 PM
09/12/09 01:55 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I would go stright to comp cams .They helped me put together a package with roller cam,roller lifters and valve springs.I am using the 848 amc style lifter with the EDM oiling,also sent oil up the exhaust pushrods to a solid adjuster.A cam in the low 600,s would be real easy and give you plenty of grunt What are your intentions with this build,are you assembling it yourself and what kinda car??
[Re: DLP4]
#466300
09/12/09 02:10 PM
09/12/09 02:10 PM
Posts: 3,443 Northern N.J.
hemi_doug
Northern N.J.
I went to Cam Dynamics for my custom grind roller cam and I'm very happy with it. I run power brakes so I needed something that wouls allow for enough vacuum for the power booster....My cam is .611 Intake and .545 exhaust and 245@50... I went with Morell lifters and yes you will need a bronze gear. The car ran a best of 12.1 @ 116, 4000 lb car and a 4 speed. I know it has mid 11s in her, I just have to get the suspension dialed in. Go roller and don't look back, it's well worth the extra $$$$$....and it works well on the street.
71 440-6 4spd & 69 Hemi 4spd
[Re: hemi-itis]
#466303
09/12/09 05:15 PM
09/12/09 05:15 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Bush the lifter bores.
Otherwise you can and probably will run into some issues, especially if it's an original(old) casting that's been handed around a lot over the years.
MB
Would you provide pressurized oil to the lifters??
yep.
[Re: DLP4]
#466308
09/12/09 09:57 PM
09/12/09 09:57 PM
hemi_doug
Northern N.J.
six-barrel - did the custom grind have a premium charge? I see Crower has an off-the-shelf cam with similar specs. Did you use Crower lifters?
I need a valve spring compressor. Is there anything around that will work with the heads on or off?
If you want to do it right I would take the heads off and get the valve tip and spring heights correct...also clean up the valves and seats. You're gonna want to degree the cam as well...
[Re: hemi_doug]
#466309
09/12/09 10:30 PM
09/12/09 10:30 PM
Posts: 123 usa
DLP4
usa
If you want to do it right I would take the heads off and get the valve tip and spring hights correct...also clean up the valves and seats. You're gonna want to degree the cam as well...
Thanks for good advice. I've got the heads off but since I need to buy a spring compressor I thought it would be nice to have one that would allow me to pull the springs with the heads on if I need it later. But it looks like this would be two different tools
[Re: six-barrel]
#466310
09/12/09 10:33 PM
09/12/09 10:33 PM
Here's one I got from Crowler.
never heard of them. do they make cams?
