Page 3 of 3 1 2 3
Re: Holes in cowl hood [Re: B1KILLER] #466088
09/12/09 05:04 PM
09/12/09 05:04 PM
On tunnel ram and dominator equipped cars I would go with a aero style scoop. I had one on my S/G car and it worked well..There is a reason all the pro stock are running them, they are worth a bunch over the older style snorkle scoops.
Re: Holes in cowl hood [Re: 572_dup2] #466089
09/12/09 05:18 PM
09/12/09 05:18 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
maybe this?
just make sure it is high enough
Re: Holes in cowl hood #466090
09/12/09 05:33 PM
09/12/09 05:33 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I'd be tempted to try ducting air from the inboard headlamp openings into hats (or an oval box) for the carbs, and use a cowl hood without the front holes.
30 years ago, we proved the deal with air sucking the mixture out the tops of the carbs on a tunnel-ram '57 SB Vette; fabricating a simple cover that blocked air from the front & back but open on the sides, using a simple flat sheet of aluminum, fixed that, but it sure was ugly.
If you can borrow an aero scoop, mock it up to determine if you can see the 'tree while staging.
Venting the hood at the rear will get rid of the air in the engine compartment hitting the firewall.
Re: Holes in cowl hood [Re: B1KILLER] #466091
09/12/09 10:28 PM
09/12/09 10:28 PM
NYC
Dartari Offline
Dartari  Offline
NYC
hemi hood is the best.
Re: Holes in cowl hood [Re: Dartari] #466092
09/12/09 10:43 PM
09/12/09 10:43 PM
EVEN the taller max wedge scoop would be period correct for your car and be the best functioning.
Re: Holes in cowl hood [Re: Bigcube] #466093
09/12/09 11:17 PM
09/12/09 11:17 PM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
Show me a pic of the hood an scoop it needs.
Have you ever seen the clear plexiglass scoops? I think RT540 had one and I saw cars in Orland with them. They don't detract from the car or hood since they are clear. They have a good size opening too. [/quote
Sounds like ORSCA Limited Street nitrous cars..
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: Holes in cowl hood #466094
09/12/09 11:26 PM
09/12/09 11:26 PM
Salina ks
572_dup2 Offline OP
Back On The Bumper!!
572_dup2  Offline OP
Salina ks
I personaly not interested in a period correct hood. It looks great on ur hot rod but not for me.
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466095
09/13/09 01:04 AM
09/13/09 01:04 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I can't even imagine how tall a "period correct" scoop would have to be to fit Shawns car, I think a MW scoop that tall would be one ugly beast.
Gonna have to be an aero scoop to fit that setup.
That's what I like about Shawn "dare to be different" and use what works best (heaven forbid) instead of what the "Mopar Gods" deemed correct.
Go for it, I wanna see a bumper draggin 8 second time slip
The scoop works for AJ and I'm pretty sure his car's all Mopar (if it matters )
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: Holes in cowl hood [Re: Sledge_57] #466096
09/13/09 04:45 AM
09/13/09 04:45 AM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
when you all in to hood scoops here are more info
some youtube airflow vidīs
web page
web page
web page
Re: Holes in cowl hood [Re: Tobbe] #466097
09/13/09 06:03 AM
09/13/09 06:03 AM
Sweden
Tobbe Offline
Tobbe  Offline
Sweden
Re: Holes in cowl hood [Re: 572_dup2] #466098
09/13/09 09:49 AM
09/13/09 09:49 AM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
Maybe you could get the Wescotts to help you. They run a PERIOD CORRECT type scoop and with less than 450 cubic inches they are running 8.40's @ 155 to 158.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Holes in cowl hood [Re: 572_dup2] #466099
09/13/09 07:27 PM
09/13/09 07:27 PM
then why do you still push transmission buttons,on your dash, do you still have your bench seat or did you take it out?
goodluck with your venture.
Re: Holes in cowl hood #466100
09/13/09 09:39 PM
09/13/09 09:39 PM
Salina ks
572_dup2 Offline OP
572_dup2  Offline OP
Salina ks
I like my push buttons an my bench seat cause its different. I dont wanna be like everyone else. Sometimes it bits me in the butt, but im different an my car reflects it.
An ya my hood will be different too
Shawn Jennings
Re: Holes in cowl hood [Re: 572_dup2] #466101
09/14/09 11:31 AM
09/14/09 11:31 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Carbs are way to close to the top of the hood..you have to have atleast 1 inch over the vent tubes..2 inch is more like it..put you a nice looking aero scoop on it...I bet it would pick up 2 tenths..
I would have said the same thing an hour ago but then I saw the pics at Moparmax.com of both of the Wescot's cars at Indy.
http://www.moparmax.com/events/2009/iv_9-hemi-1.html
The vents look like they are holding the scoop up LOL. Conventional wisdom says that should not work . Duh.
I think I would try the short aero scoop on top of your existing cowl hood like a few others have suggested.
Re: Holes in cowl hood [Re: GomangoCuda] #466102
09/14/09 12:18 PM
09/14/09 12:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve been debating the issue of air horn clearance for years simply based on the super stock hemi`s......
Page 3 of 3 1 2 3
