My alternator no longer lines up as the brackets seem to have bent some. Since I have to redo the alternator mounts I would like to find a smaller diameter crank shaft pully so I can slow the water pump, alternator, and power steering pump. Hopefully this would help the belt to oil filter clearance(miloden oil pump has the filter too close)
Where can I get a smaller crack pully and maybe a deep grove alternator pully?
Twin turbo 440 72 barracuda
