Re: Rear main..rubber or rope???
[Re: MNobody]
#465793
09/11/09 08:21 PM
09/11/09 08:21 PM
RapidRobert
The factory knurling can cause a neoprene seal to have a short life. I have a rope seal for a SB from car quest that I am going to use in this 451 build & see how it does.
[Re: terzmo]
#465799
09/12/09 07:42 AM
09/12/09 07:42 AM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
can it be done without pulling the motor?
I am wondering if it can be done also. I have a Lakewood Bellhousing and block plate on mine.
My crank is aftermarket and does not have the knurling on it like the factory ones do.
[Re: Blakcharger440]
#465800
09/12/09 09:56 AM
09/12/09 09:56 AM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I'd use a neoprene seal on a smooth crank, rope on a knurled crank.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
#465805
09/13/09 11:07 AM
09/13/09 11:07 AM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
yes, i installed a rope rear main seal without pulling the motor, however i think i did have to take out the motor mount bolts and jack up the motor to get my oil pan off, i have 68'coronet with 440 and you do have to take out the center link, once this was done it was not that bad, you have to make sure you get all the old seal out and cleaned up before installing the new seal, they make a kit to install they rope seal, a piece of wire with t-handle, and you just pull the new seal in trim off the excess and use some black rv and you are good to go.
[Re: JohnRR]
#465806
09/13/09 08:52 PM
09/13/09 08:52 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Are you sure it's the rear main seal? The seal can be changed in the car , it's not fun if doing it on your back. Putting a rope seal in in the car , that would be an interesting job .
what else would it be?? leaking oil out the bottom of inspection cover....4 speed
[Re: terzmo]
#465807
09/14/09 07:44 PM
09/14/09 07:44 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Camshaft plug on back of block.
[Re: JohnRR]
#465810
09/14/09 08:53 PM
09/14/09 08:53 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
2 main oil galley plugs in the back or the block
Input shaft seal on trans...
