Rear main..rubber or rope??? #465791
09/11/09 05:30 PM
09/11/09 05:30 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Rear main on a 440 motor just seems to keep leaking....4 speed tranny...what is best to use and does tranny have to come out to install it? thanks moparts....thanks to all in advance..rope or rubber??
Re: Rear main..rubber or rope??? [Re: terzmo] #465792
09/11/09 06:38 PM
09/11/09 06:38 PM
MNobody Offline
MNobody  Offline
I was told to use the neoprene seal from Napa.
Re: Rear main..rubber or rope??? [Re: MNobody] #465793
09/11/09 08:21 PM
09/11/09 08:21 PM
The factory knurling can cause a neoprene seal to have a short life. I have a rope seal for a SB from car quest that I am going to use in this 451 build & see how it does.
Re: Rear main..rubber or rope??? [Re: RapidRobert] #465794
09/11/09 08:47 PM
09/11/09 08:47 PM
MNobody Offline
MNobody  Offline
Your just a barrel of good news..
Re: Rear main..rubber or rope??? [Re: MNobody] #465795
09/11/09 09:11 PM
09/11/09 09:11 PM
who me
Re: Rear main..rubber or rope??? [Re: RapidRobert] #465796
09/11/09 10:00 PM
09/11/09 10:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Neoprene seal in this since 1992,never leaked a drop.
Re: Rear main..rubber or rope??? [Re: terzmo] #465797
09/12/09 01:28 AM
09/12/09 01:28 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i had to change to a rope seal in my 440, however still get a little drip here and there.
Re: Rear main..rubber or rope??? [Re: cornet684me] #465798
09/12/09 07:27 AM
09/12/09 07:27 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
can it be done without pulling the motor?
Re: Rear main..rubber or rope??? [Re: terzmo] #465799
09/12/09 07:42 AM
09/12/09 07:42 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I am wondering if it can be done also. I have a Lakewood Bellhousing and block plate on mine.
My crank is aftermarket and does not have the knurling on it like the factory ones do.
Re: Rear main..rubber or rope??? [Re: Blakcharger440] #465800
09/12/09 09:56 AM
09/12/09 09:56 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
I'd use a neoprene seal on a smooth crank, rope on a knurled crank.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Rear main..rubber or rope??? [Re: CJK440] #465801
09/12/09 10:06 AM
09/12/09 10:06 AM
Virginia
JimG Offline
JimG  Offline
Virginia
https://board.moparts.org/ubbthreads/show...rue#Post5447284
You can change the seal with the trans in and with the engine in, provided you can use profanity effectively.
Re: Rear main..rubber or rope??? [Re: JimG] #465802
09/13/09 08:11 AM
09/13/09 08:11 AM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
Being in the military for over 30 years....I have a profound proficiency in profanity...Thanks for all replies...Thanks moparts
Re: Rear main..rubber or rope??? [Re: terzmo] #465803
09/13/09 08:32 AM
09/13/09 08:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Are you sure it's the rear main seal? The seal can be changed in the car , it's not fun if doing it on your back. Putting a rope seal in in the car , that would be an interesting job .
Re: Rear main..rubber or rope??? [Re: JohnRR] #465804
09/13/09 08:44 AM
09/13/09 08:44 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
they do sell those tools to pull a rope seal thru. Looks like a wire chinese finger cuff on the end of a cable. I bought a couple because I was going to tackle the job once but didn't so I can't comment on the job.
Re: Rear main..rubber or rope??? [Re: Blakcharger440] #465805
09/13/09 11:07 AM
09/13/09 11:07 AM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
yes, i installed a rope rear main seal without pulling the motor, however i think i did have to take out the motor mount bolts and jack up the motor to get my oil pan off, i have 68'coronet with 440 and you do have to take out the center link, once this was done it was not that bad, you have to make sure you get all the old seal out and cleaned up before installing the new seal,
they make a kit to install they rope seal, a piece of wire with t-handle, and you just pull the new seal in trim off the excess and use some black rv and you are good to go.
Re: Rear main..rubber or rope??? [Re: JohnRR] #465806
09/13/09 08:52 PM
09/13/09 08:52 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
what else would it be?? leaking oil out the bottom of inspection cover....4 speed
Re: Rear main..rubber or rope??? [Re: terzmo] #465807
09/14/09 07:44 PM
09/14/09 07:44 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Camshaft plug on back of block.
Re: Rear main..rubber or rope??? [Re: 62maxwgn] #465808
09/14/09 08:08 PM
09/14/09 08:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
2 main oil galley plugs in the back of the block
Re: Rear main..rubber or rope??? [Re: JohnRR] #465809
09/14/09 08:52 PM
09/14/09 08:52 PM
Pendleton NY
terzmo Offline OP
terzmo  Offline OP
Pendleton NY
I guess those are legitimate areas of concern...I also was thinking that as I pulled into My insurance agents office, He thought the car was overheating but temp was nice at 180...I may have a leaky valve cover or two...I can't see a rear main or others causing smoke....while the oil from the covers could be hitting the exhaust manifolds or exhaust itself....haven't had time to look as My other car is acting up
Re: Rear main..rubber or rope??? [Re: JohnRR] #465810
09/14/09 08:53 PM
09/14/09 08:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
2 main oil galley plugs in the back or the block
Input shaft seal on trans...
