which KB pistons for a 451 #465714
09/11/09 04:30 PM
09/11/09 04:30 PM
RapidRobert Offline OP
400 blk 3.75". rb crank. What part # (kb hyper) do I need to look at? Closed chamber heads & I would mill the quench dome to get ~9.5-10.1. thank you for your time.
Re: which KB pistons for a 451 [Re: RapidRobert] #465715
09/11/09 05:09 PM
09/11/09 05:09 PM
Seattle, WA
rss Offline
rss  Offline
Seattle, WA
KB215s???
IIRC, you responded to an earlier post of mine on stroker buids and were planning to use 440 rods for your 451. I think the KB 215s use a 383/400 length connecting rod instead of the 440 rod. I don't recall seeing a KB piston for the 451 that used the 440 rod. I think others (440Source, Diamond, Ross) have forged pistons for the 451 that use the 440 rod. I'm just beginning to look into this myself, so it is very likely that I could be wrong.
Re: which KB pistons for a 451 [Re: RapidRobert] #465716
09/11/09 05:27 PM
09/11/09 05:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Closed chamber head , KB piston shouldn't even be an option , plus you don't need a quench dome with a closed chamber head
Re: which KB pistons for a 451 [Re: JohnRR] #465717
09/11/09 06:03 PM
09/11/09 06:03 PM
Sunny So. Cal.
mopar68 Offline
mopar68  Offline
Sunny So. Cal.
For use with stock 440 rods web page
And for stock 383 400 rods KB215 and KB251
Re: which KB pistons for a 451 [Re: RapidRobert] #465718
09/11/09 06:23 PM
09/11/09 06:23 PM
VA
DAMOPARS Offline
DAMOPARS  Offline
VA
Why not go with SRP pistons I did they are very nice.
http://www.flatlanderracing.com/
Re: which KB pistons for a 451 [Re: JohnRR] #465719
09/11/09 06:39 PM
09/11/09 06:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
KB280 with the 440 rod, but the quench pads *will* need to be milled.
You do if you are using a thick head gasket and want to maintain quench and the right CR... also Eagle H-beams are something like .008 shorter than the stock 440 rod length, and the KB280 sits .010 down in the hole to allow for decking the block.
With the H-beams the piston flat should be .018 down the hole - and I did actually measure and confirm this. So I had my quench domes milled down to .030 high.
Using a .051 thick head gasket, that means the dome has a positive deck height (sticks out above the block) .012", resulting in a .039 quench distance.
CR calculated out to 10.4:1 after I cc'ed my chambers.
Measure twice, cut once!
-Charles
Re: which KB pistons for a 451 [Re: RapidRobert] #465720
09/11/09 06:43 PM
09/11/09 06:43 PM
Thanks guys. Charles I have some felpro blue SB ones that are .054". The .051" ones you mention is that the compressed thickness of the BB versions of the same felpro blue gasket?
Re: which KB pistons for a 451 [Re: RapidRobert] #465721
09/12/09 11:15 AM
09/12/09 11:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no , most of the felpro BB blue gaskets are .040 nominal ...
Re: which KB pistons for a 451 [Re: JohnRR] #465722
09/12/09 11:37 AM
09/12/09 11:37 AM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
It is a Felpro 1039 gasket and it is .051" thick. Believe it or not, sometimes I do know what I'm talking about
Re: which KB pistons for a 451 [Re: DrCharles] #465723
09/12/09 09:48 PM
09/12/09 09:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Who said you didn't know what you were talking about, I said MOST
But like mr. rapidrobert I should not chime in on subjects I have little knowledge
Re: which KB pistons for a 451 [Re: JohnRR] #465724
09/12/09 11:36 PM
09/12/09 11:36 PM
alright I will order some KB 280's & mill the dome for quench distance. Any suggestions for a ballpark CR figure to shoot for (iron heads/stock cam/87 octane). Low rpm daily driver.
Re: which KB pistons for a 451 [Re: RapidRobert] #465725
09/13/09 01:50 AM
09/13/09 01:50 AM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Don't forget to consider your operating altitude. Approximate 10% static compression loss per 2500 ft.
Or not...
Re: which KB pistons for a 451 [Re: RapidRobert] #465726
09/13/09 03:31 AM
09/13/09 03:31 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Why bother with Hypers? I'm using KB823's (forged), with Stealth heads @ 84cc, I had the block decked to 0, provides about 10.4:1 with quench.
Re: which KB pistons for a 451 [Re: StealthWedge67] #465727
09/13/09 11:13 AM
09/13/09 11:13 AM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
The hassle is trying to find pistons for this combo in a .030 over. They are all 33 or 35.
Re: which KB pistons for a 451 [Re: GwaiiEagle] #465728
09/13/09 12:08 PM
09/13/09 12:08 PM
Puyallup, WA
Puyallup, WA
Well, if he hasn't bought pistons yet, I doubt he's had the block bored & honed. So, what difference does it make whether it's .030 over or .033 over?
Re: which KB pistons for a 451 [Re: GwaiiEagle] #465729
09/13/09 12:40 PM
09/13/09 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
4.375(.033 over) is a VERY POPULAR ring size AND it's what most GOOD off the shelf 400 based stroker pistons are sized at .
Re: which KB pistons for a 451 [Re: JohnRR] #465730
09/13/09 12:51 PM
09/13/09 12:51 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
And he could always get file-to-fit rings and set the proper (large) top ring gap for the hypers
Re: which KB pistons for a 451 [Re: DrCharles] #465731
09/13/09 01:07 PM
09/13/09 01:07 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With hypers you don't need to go thru the hassle of getting a file fit ring , the std ring size for the give bore is your file fit ring , getting a .005 oversize is just making more work for oneself .
Re: which KB pistons for a 451 [Re: JohnRR] #465732
09/13/09 01:33 PM
09/13/09 01:33 PM
Thank you double R, I had forgotton about that. Certainly no need to spring for file fit. They rough bored it as it had some rust to see what it would clean up at & they called & said 30 over. Any suggestions for CR and piston clearance?
Re: which KB pistons for a 451 [Re: RapidRobert] #465733
09/13/09 04:58 PM
09/13/09 04:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
compression I assume you want it pump gas friendly ? 9.5 steel heads , with good quench , 10 - 10.5 alum with good quench , piston clearance is set by the piston you choose , don't hone till you have the pistons in hand .
