Moroso water pump drive
#463760
09/09/09 09:02 AM
09/09/09 09:02 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
This question is for a small block powered, mildly built bracket car. Is it worthwhile using a belt driven water pump drive setup like Moroso's cog belt/electric motor, or am I better off keeping the stock crank driven setup? I know that the Moroso motor will free up some HP but will it cool as well as the stock setup doing hot laps?
This is the land of the free
because of the brave
Re: Moroso water pump drive
[Re: S/ST 3040]
#463763
09/09/09 11:01 AM
09/09/09 11:01 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I used one on my last car W/ the 440 for 4 yrs and never had a problem. That same kit is now on the 72 W/ a 360 and doing just fine.
Both cars had alum rads though.
[Re: WILD BILL]
#463765
09/09/09 04:12 PM
09/09/09 04:12 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
After killing 2 motors and then going to a HD heater fan Motor from a semi and it lasted but I ditched the set up. If you are going to run one make sure to run the belt LOOSE. No tension on it or it will take out the motor bushings. It worked when it worked but ----. I went with a Moroso electric pump.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#463766
09/09/09 06:11 PM
09/09/09 06:11 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
On my wife's '68 Cuda with a SB and an aluminum radiator and an 8 blade water pump.
I just switch from the belt drive to the Moroso motor and the car picked up over 2 tenths and the car cools 10times faster and we don't have to spray down the radiator. It used to take almost the all the time between rounds to get it cooled down because you had to start it up 3 or more times to move the water in the system and that added heat. Now it's so quick by the time you've hooked up the battery charger and wrote down your numbers in the log book it's cooled off.
Pull into the water box at 160 and it's 200 by the time you get back to the trailer. We cool it off until it gets to 160 or below.
Best thing I've ever done to the car.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: WadeMetzinger]
#463767
09/09/09 07:15 PM
09/09/09 07:15 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Years ago on my DartSport I switched from a mechanical setup to the Moroso water pump drive kit and dropped 2 tenths. But it didn't keep my mild 451 big block cool enough, I switched to a used Meziere that I got a good deal on and was much happier.
What I did like about the Moroso was that I could switch out the water pump pulley and the belt and run the mechanical pump on the street but swapping it out became a big pain.
[Re: rbstroker]
#463768
09/09/09 07:15 PM
09/09/09 07:15 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I would think it would be easier to MANAGE temps vs. the stock setup. As far as cooling capabilities...the radiator health/material, water wetter/aditive, water neck restrictors and overall running temp of the motor would provide many, many veribles here.
I can say, that on various combos, I have seen 1-2 tenths and NEVER had any issues hot lapping...even in Sacramento's summer temps.
