4spd vs. 904 #463707
09/09/09 08:26 AM
09/09/09 08:26 AM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
Which is faster in the 1/4 , anyone make the switch ? Did u gain or lose
Re: 4spd vs. 904 [Re: mrart01] #463708
09/09/09 08:45 AM
09/09/09 08:45 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
All things being equal a 4 speed will beat an automatic every time.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 4spd vs. 904 [Re: sixpackbee] #463709
09/09/09 08:47 AM
09/09/09 08:47 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
4spd is always FASTER. ET's could go either way.
Re: 4spd vs. 904 [Re: LAR_414] #463710
09/09/09 09:27 AM
09/09/09 09:27 AM
Next time your at the track see what every racer is running just about every car will have an automatic in it, i;ll put a auto up against a 4-speed any day of the week..
Re: 4spd vs. 904 #463711
09/09/09 09:41 AM
09/09/09 09:41 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Ask Charlie Westcott [ War fish ] Now they want to penalize him because he's running a stick.
Re: 4spd vs. 904 [Re: mrart01] #463712
09/09/09 10:36 AM
09/09/09 10:36 AM
Cab_Burge Online work
Cab_Burge  Online Work
It depends on the car and driver If you could make all things equal the stick trans and clutch has less parasitic drag and torque converter slippage so it will be faster and quicker due to those reasons, at least on paper Your results may vary
Re: 4spd vs. 904 [Re: Cab_Burge] #463713
09/09/09 10:59 AM
09/09/09 10:59 AM
LAR_414 Offline
LAR_414  Offline
Don't get confused on auto vs stick at the track. People run the autos, because they are CONSISTENT and easier to hook up and easier to shift. Makes for great bracket racing.
Doesn't mean they are FASTER or Quicker......just easier.
Re: 4spd vs. 904 [Re: LAR_414] #463714
09/09/09 11:02 AM
09/09/09 11:02 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I'd bet on the 904 over 95% of "833" racers.
Re: 4spd vs. 904 [Re: S/ST 3040] #463715
09/09/09 12:25 PM
09/09/09 12:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I went 11 rounds one day and beat a 340/904 combo in the final round for the win with an "833"
Gus
64 Plymouth Savoy
Dana 60
Re: 4spd vs. 904 [Re: S/ST 3040] #463716
09/09/09 12:31 PM
09/09/09 12:31 PM
I'll second that...
Re: 4spd vs. 904 [Re: S/ST 3040] #463717
09/09/09 12:33 PM
09/09/09 12:33 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
You can't duplicate the torque multiplication of an automatic torque converter with a stick. They are almost always quicker but less efficient.
The trick setup would be an automatic that locks up the converter after the launch. You get the best of both worlds. I dont know any mopar guys doing it. I think a lockup 904 wouldnt survive with much more torque than a stock motor at WOT.
There are some GM guys with this setup.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: 4spd vs. 904 [Re: Rapid340] #463718
09/09/09 12:45 PM
09/09/09 12:45 PM
LAR_414 Offline
LAR_414  Offline
Not a perfect comparison, but look at SS/AH class. There you have 727 cases with 904 guts and every trick rollerbearing known to man. Very very efficent converters and transmissions. You also have 4spd stick cars there. I'm not sure what stick they are, but they are still a stick.
The stick cars are a little lighter weight, so it's not a perfect comparison at all.
Stick cars out MPH the 904's, and they are at about the same ET....right now.
Re: 4spd vs. 904 [Re: LAR_414] #463719
09/09/09 01:01 PM
09/09/09 01:01 PM
S/ST 3040 Offline
S/ST 3040  Offline
SS/AH ala Charlie Wescott Sr.
Re: 4spd vs. 904 [Re: fourgearsavoy] #463720
09/09/09 01:02 PM
09/09/09 01:02 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Gus
Doesn't mean you are quicker or bang the gears any better. Just had a better package.
Back 'in the day' the 4 gear cars were quicker but do to improvements in transmission parts and converters available that no longer is as true as it once was. Also there aren't that many good 4 speed drivers left. Used to see a lot of 4 speed drivers that could bang a gear keeping the right foot on the floor (I could even do it (no more)) but not so many any more.
Re: 4spd vs. 904 [Re: fourgearsavoy] #463721
09/09/09 01:07 PM
09/09/09 01:07 PM
S/ST 3040 Offline
S/ST 3040  Offline
Gus
I meant in the same package.
All's I'm saying is; most 833 guys can't nail their shifts with any kind of consistancy.
You might be in that other 5% though.
edit: I also see you don't run the 833 anymore.
Re: 4spd vs. 904 [Re: S/ST 3040] #463722
09/09/09 03:06 PM
09/09/09 03:06 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Now I will confuse everyone with this, In the mud I have never seen anyone shift fast enough to keep up with a auto trans, most manual shift trucks fall flat on the shift, the resistance in the mud is grater than pavement and instantly slows down the drive line dropping rpm too much on clutch release, this factor must come to play in drag racing to some extent Just something to kick around
Re: 4spd vs. 904 [Re: emarine01] #463723
09/09/09 07:34 PM
09/09/09 07:34 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
the combo i have i bought off of a class racer w/ a 360 /904 since i have a 340 i`m looking 4 any advantage i can get over a 360 even if it`s a 904...727...or 4 spd.
Re: 4spd vs. 904 [Re: mrart01] #463724
09/09/09 07:54 PM
09/09/09 07:54 PM
S/ST 3040 Offline
S/ST 3040  Offline
Who did you get it from?
Re: 4spd vs. 904 [Re: S/ST 3040] #463725
09/09/09 08:08 PM
09/09/09 08:08 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
vance cummins out of grand haven michigan
Re: 4spd vs. 904 [Re: mrart01] #463726
09/09/09 08:17 PM
09/09/09 08:17 PM
MI
68shifter Offline
68shifter  Offline
MI
4 speed for me, and for alot of years. But a 4 speed will probably cost twice as much starting from scratch than an auto. It all depends on what you want. If you want something only 5% can shift and have that ego push, excellent. Otherwise get what everyone can drive and stay with the auto.
Just my
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
