Flex or fixed fan?? #463219
09/08/09 07:03 PM
09/08/09 07:03 PM
Gator73 Offline OP
Gator73  Offline OP
I don't like the idea of it but due to shroud clearance issues ( I need a 16 inch fan) I may have to resort to an aftermarket flex fan on my 74 Runner. I looked on Summit's website and there are not many choices for flex fans in the 16 inch range. There are aftermarket fixed fans in the 15-15.25 range. Would a smaller fixed fan move more air than a 16 inch flex fan? Anybody have any experience with flex fans and if so, what brands/styles move the most air?
Re: Flex or fixed fan?? [Re: Gator73] #463220
09/08/09 07:19 PM
09/08/09 07:19 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Don't use a flex fan,
Re: Flex or fixed fan?? [Re: Challenger 1] #463221
09/08/09 08:16 PM
09/08/09 08:16 PM
Gator73 Offline OP
Gator73  Offline OP
I have always heard that flex fans are not a good option but can anyone explain their short comings and why they don't work? The various manufacturers claim they move a lot of air and they are still produced so someone must be buying them. Just wondering why they get such a bad rap.
Re: Flex or fixed fan?? [Re: Gator73] #463222
09/08/09 08:37 PM
09/08/09 08:37 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
Some folks swear by them, but they can fail with bad stuff happening - especially if you're nearby.
Flex Fans
Re: Flex or fixed fan?? [Re: Reggie] #463223
09/08/09 08:43 PM
09/08/09 08:43 PM
Cincinnati, Ohio
Cincinnati, Ohio
Flex Fans
WOW!!
I just didn't think they moved enough air IMO.
I never even thought about that!
Re: Flex or fixed fan?? [Re: Reggie] #463224
09/08/09 09:37 PM
09/08/09 09:37 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I could see it being bad if an aluminum blade hit you in the neck...As for it "severing a persons arm at the shoulder"....Now I don't believe ANY of it.
Re: Flex or fixed fan?? [Re: Bill MeLater] #463225
09/08/09 10:27 PM
09/08/09 10:27 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
A pic from a Chevy forum.
Re: Flex or fixed fan?? [Re: Bill MeLater] #463226
09/08/09 10:38 PM
09/08/09 10:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Very possible with the blade coming off. They are very sharp and at speed are just like a knife. I have seen them cut into a hood at high RPM.
Re: Flex or fixed fan?? [Re: Bill MeLater] #463227
09/09/09 12:19 AM
09/09/09 12:19 AM
South Carolina
FM3_1970 Offline
FM3_1970  Offline
South Carolina
There were a bunch of lawsuits about flex fan injuries filed against GMC in the 1990s. IIRC, in one of them a piece of a flex fan supposedly severed the guy's nerves in his shoulder so he couldn't use his arm any more. That may be the source of this story.
Re: Flex or fixed fan?? [Re: FM3_1970] #463228
09/09/09 12:51 AM
09/09/09 12:51 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Had a flex fan on my RR for 30 years with no problems, but I think the blades were steel with thicker steel plates sandwiching them to the hub with the rivets. Aluminum work hardens fast, so all that flexing can make the blades brittle.
On the other hand, I don't think I've ever seen a factory car with a flex fan, so maybe that says something also.
Re: Flex or fixed fan?? [Re: MoparMarq] #463229
09/09/09 08:17 AM
09/09/09 08:17 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
The summit stainless flex has been on my 65 for at least 15 years.I also ran one on my Jeep that was daily driver and snow plow.My kid has one on his 360 also.If its quality its as strong as any fan.My 440 runs at 180 all day with an untouched OE rad.As far as that pic of the broken one it ht something and almost amy fan will break if its hitting steel.Ive had one fan break in over 40 years and it was a factory fan.Stay away from the glass fans as they arent as strong as a good stainless one.Rocky
Chrysler Firepower
Re: Flex or fixed fan?? [Re: therocks] #463230
09/09/09 08:32 AM
09/09/09 08:32 AM
Az
Crizila Offline
Crizila  Offline
Az
Flex fans have come a long ways in the last 10 years. Failures are rare anymore. Most the blades are stainless and a good flex fan will move more air at idle than any fixed blade OEM style fan. HP savings can be considerable. A flex fan is the only way to go if your not going electric - or not doing any off roading.
Fastest 300
Re: Flex or fixed fan?? [Re: Crizila] #463231
09/09/09 11:04 AM
09/09/09 11:04 AM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
First hand experience.buddy just redid his cooling system 67 fairlane 390 4 spd.new rad. and flex fan.Banging gears-slight over rev.The fan flexed outward and took out the new radiator.stuff was only a week old.I was with him.
Re: Flex or fixed fan?? [Re: moretoys] #463232
09/09/09 11:20 AM
09/09/09 11:20 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I doubt it was the fan flexing that did it.Mine has seen over 7K regulary and the 65 has one of the closest fans there is.Sounds like junk mounts so blame it on the fan.Rocky
Chrysler Firepower
Re: Flex or fixed fan?? [Re: therocks] #463233
09/09/09 01:10 PM
09/09/09 01:10 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
Any fan can break whether it be a flex or factory clutch fan. Both serve specific purposes and both are fine to use in the right application.
I had a factory fan blade go thru the hood on my 1972 Chevy 402 pickup one time while driving 60mph on the highway. It scared me chitless!
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Flex or fixed fan?? [Re: MY340] #463234
09/09/09 03:34 PM
09/09/09 03:34 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My factory one in the 65 broke in the drive on start up.One blade came all the way off.Most break from abuse period.Rocky
Chrysler Firepower
Re: Flex or fixed fan?? [Re: therocks] #463235
09/09/09 06:27 PM
09/09/09 06:27 PM
Morris County NJ
Rustydog Offline
Rustydog  Offline
Morris County NJ
I have used them for over 30 years.
Never had a problem.
I have one on my Ray Barton 472 Hemi. (70 Challenger)
I have one on my 440 68 Dart.
I have one on 318 Poly 66 Coronet.
Over the years I've had them on over 30 cars.
Just for the record, Ray Barton himself told me when he saw my Challenger that he does NOT like aluminum flex fans.
Go figure.
Re: Flex or fixed fan?? [Re: Rustydog] #463236
09/09/09 07:26 PM
09/09/09 07:26 PM
Gator73 Offline OP
Gator73  Offline OP
Of those of you who have used flex fans and had good luck, what brand(s)did you run? It appears that the most prominent fans are Flex-a-lite. Summit also carries Derale. I read on another post that the style or taper of the blades will make a difference in how the fan functions and the amount of air it will move. It was suggested that one look for a heavy duty flex fan. I don't know if that is opposed to one designed for racing applications or what.
Re: Flex or fixed fan?? [Re: Gator73] #463237
09/09/09 07:48 PM
09/09/09 07:48 PM
IA
landon1 Offline
landon1  Offline
IA
mine is a 17" flex-a-lite. been on there for 6 years now - factory fan blade cracked at the hub area that mounts to the wp pulley
'71 Satellite Sebring 440
Re: Flex or fixed fan?? [Re: stumpy] #463238
09/10/09 09:45 AM
09/10/09 09:45 AM
Wisconsin USA
Wisconsin USA
Granted: BUT who stands over their flex fan and zings the motor to 6 grand?
