Re: Fast 3.75"-stroke 440 combos?
[Re: BradH]
#46245
10/11/07 12:47 PM
10/11/07 12:47 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
30 over 440,cast crank,eagle rods ,wiseco flat tops down .035,b1bs heads,herbert D6H roller,t-ram,8 in ptc,4.10 dana,3230 race weight
10.59 @ 125 1.42 60 ft
WAXER
[Re: QWK_ENUF]
#46246
10/11/07 01:27 PM
10/11/07 01:27 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
10.388 @ 128.80 @ 2146 DA (Had to look that one up in the old log book!)
.030 over 440 TRW flat tops, 0 deck, 79.5 cc head 5/64, 5/64 3/16 ring pack LY rods Stock 3.75 crank Crane R280 roller (.680 lift with a 1.5 rocker) 263 (peak) cfm 906 heads 2 1/8" header 4150 base M1 with 8896 Dominator/adaptor MP dist with 38 degrees total
Stock 727 with Pro Trans VB 8" (Munsinger rebuilt) A-1 converter Converter flashed 4800 on the strating line
73 Cuda 3,330 with driver, full cell, jacket and helmet. 2 x 3 back half ladder bars HAL (Now QA1) adjustable coilovers 14 x 32 med compound tire on 14" wide Welds 8.75 with a 4.89 gear 35 spline spool OEM front end OEM brakes 8 point MOLY cage
Footbrake @ 2500 leave (brakes wouldn't hold any more) 6500 shifts (went NO faster any higher..actually slowed down if ran past 6800) Accoss the stripe at 6900.
Car was all steel except glass 6-bbl (not sealed) hood. All Lexan windows. Stock dash and stock floor/firewall, except back half.
The really cool thing was going from mid 10.80's to that 10.38 without touching the motor. That was from freshening the trans/converter, replacing the bent rear end housing, and adding and tuning the shocks.
Go back and note CR, cam duration and header size. I soooooo regret not trying a 275-ish roller and 2" headers.
I'm even more remorseful for selling it to buy a STUPID COMP dragster!!
[Re: BradH]
#46247
10/11/07 02:18 PM
10/11/07 02:18 PM
.055 over 440 block 12.5 wiseco dome pistons mp .620 solid cam indy sr heads 75cc bowl blend only 0 deck with.044 head gasket from 440 source 440 source h beam rods stock forged crank torker two intake 5500 turbo action converter dana 60 rear 4.56 All steel 67 dart backhalved 4 link 14x32 tires 3160 race weight 6.45 1/8 10. 21 1/4 at 129 this was the only time i ran the 1/4 in the last 7 years Car has went as good as 6.37 1/8 in good air 1.347 sixty with 50 lbs ballast, car is,nt certified so i try to stay above 6.40.
[Re: BradH]
#46248
10/11/07 02:57 PM
10/11/07 02:57 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
440+.060 , 1963 M.W. heads with two Carter #3705 750 CFM carbs on the intake, Isky 616 solid lifter cam, comp. ratio with TRW 2295 pistons I didn't know how to figure the true compression ratio then by pouring the cylinders and so on. 4:56 gears, A1 8 inch converter, 14x32 slicks. Car was John Dianna old gas class car when Mazzolini owned it, weighed 2860 with me in it in S/G ran a best 10.08 at 132+ mph, I don't remember the exact MPH. The 60 ft. times where worst than my stocker(3750 lbs) with the same motor, trans and converter.
[Re: Cab_Burge]
#46249
10/11/07 03:12 PM
10/11/07 03:12 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
452 indy heads cast tunelram, 850 holleys,4.88,8' coan, ladderbar, #3350,10.5/31w,-8.92@153mph 1.24 60's
JAKES AUTOMOTIVE
[Re: JAKE68]
#46250
10/11/07 03:33 PM
10/11/07 03:33 PM
cudadoug
If that's all-moder...THAT's impressive!
Tell us more: Which Indy's? Piston/Rods?? CR?? Cam?? What stall converter....??
[Re: cudadoug]
#46251
10/11/07 04:06 PM
10/11/07 04:06 PM
Posts: 2,644 North Carolina
sasquatch
North Carolina
Mopar mega block bored to 4.500 Callies 3.75 stroke GRP aluminum rods 7.150 Je 15.5 to one pistons Indy 572-13 heads fully ported Jesel 1.7 rockers Indy 3x manifold Jesel belt drive Custom Chuck Nuyton dominator custom 55 MM cam shaft 985 HP at 7500 RPM and still going when the owner stopped the dyno session and took it home. at about 6300 rpm it had a whole new gear.
[Re: BradH]
#46252
10/11/07 04:16 PM
10/11/07 04:16 PM
Posts: 3,059 Swamps of South Jersey.
wildcargo
Well the old 440 was +.030 Arias 17cc domes at 0 deck notched for plug, Eagle rods, 620Mp cam, Edelbrock heads gasket matched 84cc, Team G intake, 950HP Holley, 727, 5000 ATI 8" converter, 4.56 gear 29.5x11.5x15W on a 10" rim, 64 B-body 3080# at the line with driver. Best run 60'1.433, 330 4.109, 1/8 6.388 at 107.40, 990 8.323, 1/4 10.08 at 132.02 mph, foot brake to 2500 shift at 6800 traps at 7000, Fun Ride
[Re: QWK_ENUF]
#46253
10/11/07 04:18 PM
10/11/07 04:18 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Was that on spray? what did it do on motor? and how much spray?
[Re: BradH]
#46254
10/11/07 06:38 PM
10/11/07 06:38 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
440 + .030, stock forged crank 14.5:1 CR, Manley H beam rods out of the box unported Indy SR heads 268/283 at fifty Herbert solid roller (bigger than we thought) Weiand Team G, 1050 dominator 2" - 2 1/8" TTI step headers, 4" flowmaster exhaust 5000 stall, 4.10 gear, 28x12.5 ET Streets 3700# w/ driver 10.40 at 129.1 mph CHIP
[Re: Quicksilver440]
#46255
10/11/07 06:46 PM
10/11/07 06:46 PM
QWK_ENUF
LOWELL IN
on motor no spray , only used spray for the first 10.0 race or for street races
WAXER
[Re: QWK_ENUF]
#46256
10/11/07 06:55 PM
10/11/07 06:55 PM
Quicksilver440
Central Valley, CA.
#46257
10/11/07 07:40 PM
10/11/07 07:40 PM
Posts: 2,119 sc
tjmarcus1
sc
this sounds like fun! .030 over 440, stock stroke ly rods, stock crank, trw2295 pistons flat tappet cam, e-heads, iron rockers tunnel ram 2-660's 6.06 @ 113.19mph, 1.26 60ft. i believe that equates to at least a 9.70
#46258
10/11/07 07:45 PM
10/11/07 07:45 PM
Posts: 261 eastern Ky
hilbillyconquest
eastern Ky
60 over 440 factory 3.75 , with ross domes , eagle rods , 690 lift comp roller , -1s cnc'd by modern cylinder head ,indy intake, 1050 dominator. 1.76 glide with a 5900 converter ,2350 # car with 4.86 nine inch. i put over 200 passes on it last year but only about 100 or so this year. runs high 5.60's to low 5.70's in the 1/8 , 8.90's in the 1/4.
[Re: tjmarcus1]
#46259
10/11/07 08:36 PM
10/11/07 08:36 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Wow you guys have some fast running stock stroke 440 in here. Here is the run down of my old 65 plymouth. Mopar65 65 Plymouth 2 dr. hdtp. -.030 over 440 -Eagle 6.76 rods -Ross domed pistons w/.990 pin (although our compression is probably only 11.0-11.5 with the big E-head chambers.) -Factory Forged Steel Crank -Unported E-heads - cam mopar 312/.590 degreed in at 104) with indy 1.6 roller rockers - victor 440 with a holley 1050hp or m1-4500 ported intake with ½ four hole spracer and mr,gasket safety plate -Charlie’s aluminum Super Stock 10 qt. pan with Milodon swinging pickup, external line, and oil pump. -TTI 2” x 3 ½ nickel plated headers -Accel 300+ ignition triggered by an MSD Crank Trigger and sparked through MSD distributor and wires with Champion race plugs. - dana 60 with 4.56 gears every thing else the same) -Wilwood Disc on all 4 corners. -Cal-Trac bars, springs, and shocks. -Turbo Action 4400 converter. - NEW ( -31x10.5x15w M/T with a circ. Of 99.0 We stall it to around 3200-3500 on the line, but this converter will flash up around 5200-5500 on launch. We go 1.44 60' with tuning on the Cal-Tracs. Our car weighs 3460# with driver and best speed of 10.55 at 126.9 mph local track (1600' elevation). Shift at 6500-6800 with the limiter set at 7250.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
