Page 1 of 4 1 2 3 4
Fast 3.75"-stroke 440 combos? #46244
10/11/07 12:04 PM
10/11/07 12:04 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
I know there are folks on here who have built some potent low-to-mid 10-sec (and faster) 400/440-based combinations that retain the stock 3.75" stroke. I'd like to know more about them, including the related details of the rest of the car (weight w/ driver, gearing, converter, etc.).
Thanks,
Brad
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46245
10/11/07 12:47 PM
10/11/07 12:47 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
30 over 440,cast crank,eagle rods ,wiseco flat tops down .035,b1bs heads,herbert D6H roller,t-ram,8 in ptc,4.10 dana,3230 race weight
10.59 @ 125 1.42 60 ft
WAXER
Re: Fast 3.75"-stroke 440 combos? [Re: QWK_ENUF] #46246
10/11/07 01:27 PM
10/11/07 01:27 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
10.388 @ 128.80 @ 2146 DA (Had to look that one up in the old log book!)
.030 over 440
TRW flat tops, 0 deck, 79.5 cc head
5/64, 5/64 3/16 ring pack
LY rods
Stock 3.75 crank
Crane R280 roller (.680 lift with a 1.5 rocker)
263 (peak) cfm 906 heads
2 1/8" header
4150 base M1 with 8896 Dominator/adaptor
MP dist with 38 degrees total
Stock 727 with Pro Trans VB
8" (Munsinger rebuilt) A-1 converter
Converter flashed 4800 on the strating line
73 Cuda
3,330 with driver, full cell, jacket and helmet.
2 x 3 back half
ladder bars
HAL (Now QA1) adjustable coilovers
14 x 32 med compound tire on 14" wide Welds
8.75 with a 4.89 gear
35 spline spool
OEM front end
OEM brakes
8 point MOLY cage
Footbrake @ 2500 leave (brakes wouldn't hold any more)
6500 shifts (went NO faster any higher..actually slowed down if ran past 6800)
Accoss the stripe at 6900.
Car was all steel except glass 6-bbl (not sealed) hood. All Lexan windows. Stock dash and stock floor/firewall, except back half.
The really cool thing was going from mid 10.80's to that 10.38 without touching the motor. That was from freshening the trans/converter, replacing the bent rear end housing, and adding and tuning the shocks.
Go back and note CR, cam duration and header size. I soooooo regret not trying a 275-ish roller and 2" headers.
I'm even more remorseful for selling it to buy a STUPID COMP dragster!!
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46247
10/11/07 02:18 PM
10/11/07 02:18 PM
.055 over 440 block
12.5 wiseco dome pistons
mp .620 solid cam
indy sr heads 75cc bowl blend only
0 deck with.044 head gasket from 440 source
440 source h beam rods
stock forged crank
torker two intake
5500 turbo action converter dana 60 rear 4.56
All steel 67 dart backhalved 4 link 14x32 tires
3160 race weight
6.45 1/8 10. 21 1/4 at 129 this was the only time i ran the 1/4 in the last 7 years
Car has went as good as 6.37 1/8 in good air 1.347 sixty with 50 lbs ballast, car is,nt certified so i try to stay above 6.40.
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46248
10/11/07 02:57 PM
10/11/07 02:57 PM
Cab_Burge Online work
Cab_Burge  Online Work
440+.060 , 1963 M.W. heads with two Carter #3705 750 CFM carbs on the intake, Isky 616 solid lifter cam, comp. ratio with TRW 2295 pistons I didn't know how to figure the true compression ratio then by pouring the cylinders and so on. 4:56 gears, A1 8 inch converter, 14x32 slicks. Car was John Dianna old gas class car when Mazzolini owned it, weighed 2860 with me in it in S/G ran a best 10.08 at 132+ mph, I don't remember the exact MPH. The 60 ft. times where worst than my stocker(3750 lbs) with the same motor, trans and converter.
Re: Fast 3.75"-stroke 440 combos? [Re: Cab_Burge] #46249
10/11/07 03:12 PM
10/11/07 03:12 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
452 indy heads cast tunelram, 850 holleys,4.88,8' coan, ladderbar, #3350,10.5/31w,-8.92@153mph 1.24 60's
JAKES AUTOMOTIVE
Re: Fast 3.75"-stroke 440 combos? [Re: JAKE68] #46250
10/11/07 03:33 PM
10/11/07 03:33 PM
cudadoug Offline
cudadoug  Offline
If that's all-moder...THAT's impressive!
Tell us more: Which Indy's? Piston/Rods?? CR?? Cam?? What stall converter....??
Re: Fast 3.75"-stroke 440 combos? [Re: cudadoug] #46251
10/11/07 04:06 PM
10/11/07 04:06 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Mopar mega block bored to 4.500
Callies 3.75 stroke
GRP aluminum rods 7.150
Je 15.5 to one pistons
Indy 572-13 heads fully ported
Jesel 1.7 rockers
Indy 3x manifold
Jesel belt drive
Custom Chuck Nuyton dominator
custom 55 MM cam shaft
985 HP at 7500 RPM and still going when the owner stopped the dyno session and took it home. at about 6300 rpm it had a whole new gear.
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46252
10/11/07 04:16 PM
10/11/07 04:16 PM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
Well the old 440 was +.030 Arias 17cc domes at 0 deck notched for plug, Eagle rods, 620Mp cam, Edelbrock heads gasket matched 84cc, Team G intake, 950HP Holley, 727, 5000 ATI 8" converter, 4.56 gear 29.5x11.5x15W on a 10" rim,
64 B-body 3080# at the line with driver.
Best run 60'1.433, 330 4.109, 1/8 6.388 at 107.40, 990 8.323, 1/4 10.08 at 132.02 mph, foot brake to 2500 shift at 6800 traps at 7000, Fun Ride
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Fast 3.75"-stroke 440 combos? [Re: QWK_ENUF] #46253
10/11/07 04:18 PM
10/11/07 04:18 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Was that on spray? what did it do on motor? and how much spray?
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46254
10/11/07 06:38 PM
10/11/07 06:38 PM
an8sec70cuda Offline
440 + .030, stock forged crank
14.5:1 CR, Manley H beam rods
out of the box unported Indy SR heads
268/283 at fifty Herbert solid roller (bigger than we thought)
Weiand Team G, 1050 dominator
2" - 2 1/8" TTI step headers, 4" flowmaster exhaust
5000 stall, 4.10 gear, 28x12.5 ET Streets
3700# w/ driver
10.40 at 129.1 mph
CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Fast 3.75"-stroke 440 combos? [Re: Quicksilver440] #46255
10/11/07 06:46 PM
10/11/07 06:46 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
on motor no spray , only used spray for the first 10.0 race or for street races
WAXER
Re: Fast 3.75"-stroke 440 combos? [Re: QWK_ENUF] #46256
10/11/07 06:55 PM
10/11/07 06:55 PM
Central Valley, CA.
Central Valley, CA.
Re: Fast 3.75"-stroke 440 combos? [Re: Quicksilver440] #46257
10/11/07 07:40 PM
10/11/07 07:40 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
this sounds like fun!
.030 over 440, stock stroke
ly rods, stock crank, trw2295 pistons
flat tappet cam, e-heads, iron rockers
tunnel ram 2-660's
6.06 @ 113.19mph, 1.26 60ft. i believe that equates to at least a 9.70
Re: Fast 3.75"-stroke 440 combos? [Re: Quicksilver440] #46258
10/11/07 07:45 PM
10/11/07 07:45 PM
eastern Ky
hilbillyconquest Offline
eastern Ky
60 over 440 factory 3.75 , with ross domes , eagle rods , 690 lift comp roller , -1s cnc'd by modern cylinder head ,indy intake, 1050 dominator.
1.76 glide with a 5900 converter ,2350 # car with 4.86 nine inch.
i put over 200 passes on it last year but only about 100 or so this year.
runs high 5.60's to low 5.70's in the 1/8 , 8.90's in the 1/4.
Re: Fast 3.75"-stroke 440 combos? [Re: tjmarcus1] #46259
10/11/07 08:36 PM
10/11/07 08:36 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Wow you guys have some fast running stock stroke 440 in here. Here is the run down of my old 65 plymouth. Mopar65
65 Plymouth 2 dr. hdtp.
-.030 over 440
-Eagle 6.76 rods
-Ross domed pistons w/.990 pin (although our compression is probably only 11.0-11.5 with the big E-head chambers.)
-Factory Forged Steel Crank
-Unported E-heads
- cam mopar 312/.590 degreed in at 104) with indy 1.6 roller rockers
- victor 440 with a holley 1050hp or m1-4500 ported intake with ½ four hole spracer and mr,gasket safety plate
-Charlie’s aluminum Super Stock 10 qt. pan with Milodon swinging pickup, external line, and oil pump.
-TTI 2” x 3 ½ nickel plated headers
-Accel 300+ ignition triggered by an MSD Crank Trigger and sparked through MSD distributor and wires with Champion race plugs.
- dana 60 with 4.56 gears every thing else the same)
-Wilwood Disc on all 4 corners.
-Cal-Trac bars, springs, and shocks.
-Turbo Action 4400 converter.
- NEW ( -31x10.5x15w M/T with a circ. Of 99.0
We stall it to around 3200-3500 on the line, but this converter will flash up around 5200-5500 on launch. We go 1.44 60' with tuning on the Cal-Tracs.
Our car weighs 3460# with driver and best speed of 10.55 at 126.9 mph local track (1600' elevation). Shift at 6500-6800 with the limiter set at 7250.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Fast 3.75"-stroke 440 combos? [Re: hilbillyconquest] #46260
10/11/07 08:44 PM
10/11/07 08:44 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
3.75 stoke 4.375 bore 400 block 440-1's ported 14.5 compression 727 and 4.56 gears indy intake with 9375 dominator and a 650 flat tappet cam coan 8" 5000 converter car was 3190 lbs or so with the stock block setup, ran 9.63 138.7 and 6.08 1/8th
Re: Fast 3.75"-stroke 440 combos? [Re: BradH] #46261
10/11/07 08:55 PM
10/11/07 08:55 PM
NYC
Dartari Offline
Dartari  Offline
NYC
73Dart 3350 lbs with driver 440 30 over 11.5-1 ross piston 690 lunati roller stock unported stage 1 max wedge heads stock rockers indy intake 1050 carb 4:10 gears 11.5 29.5 phoenix tires runs 10.52 @ 128 mph
Re: Fast 3.75"-stroke 440 combos? [Re: wildcargo] #46262
10/11/07 10:24 PM
10/11/07 10:24 PM
illinois
dodgeram1998 Offline
illinois
how much lead timing with those domes
Re: Fast 3.75"-stroke 440 combos? [Re: dodgeram1998] #46263
10/12/07 07:51 AM
10/12/07 07:51 AM
W
wildcargo Offline
wildcargo  Offline
W
I ran 38* total with C12 fule changing timing did not pick it up. If you use the E-head the angled plug requires a notch in the pistion with a projected tip plug AR3910 but not with a AR3931 non projected tip.
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
Page 1 of 4 1 2 3 4
