Where to buy a speedometer pinion gear? #461700
09/07/09 12:14 PM
09/07/09 12:14 PM
Illinois
SGTFURY62 Offline OP
Illinois
Anyone have a good lead on where to purchase a speedometer pinion gear? In my 63 plymouth I switched over to 3.91's and speedo is way off. I am running the original 63 auto trans and need to find the correct gear which I believe is an 8 by 20 toothed gear? Help.
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461701
09/07/09 12:32 PM
09/07/09 12:32 PM
Central Arkansas
P
Pre_RT Offline
Pre_RT  Offline
P
Central Arkansas
Picked up my last one off ebag for about $10. Here is a conversion chart I ran across. Good Luck
5467664-AxleRatio.doc (728 downloads)
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461702
09/07/09 12:32 PM
09/07/09 12:32 PM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
It "may" still be a "dealer-item." The last one I bought, was from a local dealership parts department.
I believe Year-One sells them too. They are "color-coded," There should be a link about them in the Moparts Tech archive, top of this webpage.
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461703
09/07/09 12:39 PM
09/07/09 12:39 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've always bought them at a dealer, I'm sure there's other places that have them.
Re: Where to buy a speedometer pinion gear? [Re: Challenger 1] #461704
09/07/09 12:46 PM
09/07/09 12:46 PM
Martinsville, VA
440child Offline
440child  Offline
Martinsville, VA
Brewers Performance www.brewersperformance.com has them, you might want to ask them if they will work in automatics or not.
Re: Where to buy a speedometer pinion gear? [Re: Challenger 1] #461705
09/07/09 12:48 PM
09/07/09 12:48 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Not so easy to find. 1965 and down are different gears IIRC. Might want to check here: http://www.partshp.com/speedometer_gears.htm
Re: Where to buy a speedometer pinion gear? [Re: mopars4ever] #461706
09/07/09 12:50 PM
09/07/09 12:50 PM
Cincinnati, Ohio
Cincinnati, Ohio
I was wondering that too...
Re: Where to buy a speedometer pinion gear? [Re: mopars4ever] #461707
09/07/09 12:51 PM
09/07/09 12:51 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Transmission part suppliers are the cheapest. The dealer wanted $60 for the one I needed, got it at D&E Transmission Supply for $17. They are located in Hazel Park Michigan.
Re: Where to buy a speedometer pinion gear? [Re: maximus] #461708
09/07/09 12:54 PM
09/07/09 12:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You picked up the pre 65 pinion? or post?
Cause pre's are rare, used or NOS only is what I've seen.
Don't be the exception.
Re: Where to buy a speedometer pinion gear? [Re: maximus] #461709
09/07/09 12:59 PM
09/07/09 12:59 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Funny thing, I never got one email on a NOS 2538932 (66 and later years) gear I have for sale here on Moparts for $25 and the dealer wants $79 for the same thing.
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461710
09/07/09 01:50 PM
09/07/09 01:50 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
Very hard to find any speedometer gears for 1962 to 1965 cable shift (pushbutton) transmission. Here's the info from the 1965 parts book. 1963 info is the same. The factory never made a gear for the B bodies with 3.91:1 ratio. You had to use an adapter made by stewart warner to have a correct speedometer reading.
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461711
09/07/09 01:52 PM
09/07/09 01:52 PM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
Hi,
Would you be interested in selling the one you have? How many teeth are on yours?
Re: Where to buy a speedometer pinion gear? [Re: Cuda67] #461712
09/07/09 02:34 PM
09/07/09 02:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is what you need,65 and earlier.
Re: Where to buy a speedometer pinion gear? [Re: 62maxwgn] #461713
09/07/09 02:59 PM
09/07/09 02:59 PM
Keizer, Oregon
Dadrules Offline
Dadrules  Offline
Keizer, Oregon
what rear end ratio will that fit? reason I ask - I'm finishing up a 65 barracuda and have 3.73 rear gears and I know the speedometer gear I've got is wrong. thank you.
Re: Where to buy a speedometer pinion gear? [Re: Dadrules] #461714
09/07/09 04:15 PM
09/07/09 04:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You can use any gear ratio/tire diameter calculator but you need to use 8 teeth as the drive gear for the '65 and earlier 727 instead of 13 like the '66 and later.
The early 904 and light duty standard transmissions have 7 teeth on the drive gear.
As stated earlier, high numeric gear ratios most often need a reduction unit unless the tires are large in diameter.
Re: Where to buy a speedometer pinion gear? [Re: John_Kunkel] #461715
09/07/09 10:33 PM
09/07/09 10:33 PM
Illinois
Illinois
Wow ...what a can of worms I opened up putting the lower gears in. I am only gonna guess that one of those stewart warner adapters are NOT easy to come by?
Re: Where to buy a speedometer pinion gear? [Re: SGTFURY62] #461716
09/07/09 10:37 PM
09/07/09 10:37 PM
Cincinnati, Ohio
Cincinnati, Ohio
Got a idea, get a GPS and use it for your speedo.
Re: Where to buy a speedometer pinion gear? [Re: Challenger 1] #461717
09/07/09 10:59 PM
09/07/09 10:59 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I've checked mine with those roadside radar signs and I know it's 10 mph fast.
I've got two cars with 3:23's and 235-60-15's and they are both off by 10 mph.
Re: Where to buy a speedometer pinion gear? [Re: Challenger 1] #461718
09/07/09 11:08 PM
09/07/09 11:08 PM
Illinois
Illinois
LOL..it may come to that.
Re: Where to buy a speedometer pinion gear? [Re: Cuda67] #461719
09/08/09 12:24 AM
09/08/09 12:24 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
Anyone want to sell one?
