a body front strut rods #461680
09/07/09 11:15 AM
09/07/09 11:15 AM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
I have fabbed up a set of rod end equipped strut rods and am wondering if there is some dimension or measurement that gets the lower control arm back in the car square? i took an overall length before i started but just want to double check.
Re: a body front strut rods [Re: eds dart] #461681
09/07/09 11:29 AM
09/07/09 11:29 AM
MR_P_BODY Offline
Happy Birthday MR_P_BODY  Offline
I dont know what the stock dimension would be but
you can measure from the reference holes in the frame
to the zert fitting in the ball joint to see if they
are the same
Re: a body front strut rods [Re: eds dart] #461682
09/07/09 12:56 PM
09/07/09 12:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Any photos? I plan on building a set of adjustable ones with a heim end on them.
Re: a body front strut rods [Re: justinp61] #461683
09/07/09 06:22 PM
09/07/09 06:22 PM
indy
E
eds dart Offline OP
eds dart  Offline OP
E
indy
i will see about pictures, just bought a female rod end. Fabbed up a step type 2 piece bushing for the k member end and bought a clevis bracket like for a track locator. installed the bushing/ clevis in the k member and measured to get the right length on the strut rod. cut the strut rod and threaded it. it wasnt too hard to do and it made a tremendous difference in freeing up the front end verses the poly bushings that were in there.
