68 GTX convertible colors, S6C #460447
09/05/09 10:09 PM
09/05/09 10:09 PM
Springfield VA
GTXOnsfri Offline OP
Springfield VA
Does anyone have a photo of the right interior colors for a 68 S6C blue/white GTX. What I have is all white, blue carpet and black/green instrument panel, pillars, and kick panels. The exterior is QQ electric blue poly. My guess is the upper doors should be light blue or the same blue as the exterior. Shouldn't that carry back to the top of the rear panels? So far this car has been green, red, and blue (all before I owned it). Since it's mostly blue now that's the color it will stay. I found an old post that said it was an S6C but the seats were blue. Confusing. Thanks.
Re: 68 GTX convertible colors, S6C [Re: GTXOnsfri] #460448
09/06/09 08:41 PM
09/06/09 08:41 PM
Springfield VA
Springfield VA
OK, here is a shot of the door as it is today. You can see the upper door panel is white. I think that should be blue, medium blue or bahama blue or light blue poly (this is what is on the chips sheet). I've seen armrests that are blue or white. Clueless on which is correct.8
The chips sheet also says low gloss finish Bahama blue poly for convertible upper windshield only? Where is that? For that matter, whats a garnish moulding?
Re: 68 GTX convertible colors, S6C [Re: GTXOnsfri] #460449
09/06/09 08:46 PM
09/06/09 08:46 PM
Springfield VA
Springfield VA
Here is a shot of one the rear panels. As you can see, the last owner decided that speakers (which were not in the car when I bought it) really needed to be installed (hacked) in the rear panels. New panels will have to wait. The top of the panel should be blue? white? And should it carry over across the 3-inch-wide metal cover over the rear seat?
Re: 68 GTX convertible colors, S6C [Re: GTXOnsfri] #460450
09/06/09 09:56 PM
09/06/09 09:56 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
They should be white, just like they are. Arm rests white also, the only blue is: carpet, all the dash, kick panels, and seat belts.
Re: 68 GTX convertible colors, S6C [Re: NANKET] #460451
09/07/09 12:31 AM
09/07/09 12:31 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I thought I had some pics of the white & blue '68 interior but can't seem to find them.
If you check your fender tag there will be a "W" under the "U" (for "white" - Upper Door Frame paint) on the second from bottom line. The UDF, seats, door panels, inside rear 1/4 panels, panel between them, convertible "boot", & armrests should all be "white" in varying shades. The carpet, seat belts, kick panels, dash, dash frame, A-pillars, interior windshield header (your garnish mouldings) should all be varying shades of "blue". Sun visors??
1968 only combiination (in '69 the UDF was blue on the P6C interior)
Re: 68 GTX convertible colors, S6C [Re: 6bblgt] #460452
09/07/09 02:43 PM
09/07/09 02:43 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
your car is correct as is.. blue should be on carpet, dash/pad, visors, inner windshield trim, everything else is WHITE! dan
Re: 68 GTX convertible colors, S6C [Re: ph23vo] #460453
09/07/09 06:30 PM
09/07/09 06:30 PM
Mass
Mike Mancini Offline
Mass
Door panels have a pearlescent tone like the seats. The plastic panels are two tone. white pearl and gloss white uppers and lower corners.
See pics of 68 Coronet RT Interior
Michael L. Mancini
American Muscle Car Restorations, Inc.
65 Foliage Drive
N. Kingstown, RI
Premium Quality Restoration Services for Hi-Performance & Classic Automobiles. OE Specialists.
Instrument Specialties, Inc
www.instrument-specialties.com
www.manciniresto.com
www.performancecargraphics.com
Re: 68 GTX convertible colors, S6C [Re: Mike Mancini] #460454
09/07/09 09:28 PM
09/07/09 09:28 PM
Springfield VA
Springfield VA
Great! That hits the spot. I thought the rear panel had two colors. I wasn't thinking two shades of white. I want to paint the panels before I redo the carpet. If it looks half a good as yours I'd be happy!
Did you do anything around the courtesy lights? It seems that if there were something reflective above the light, they would work better.
Re: 68 GTX convertible colors, S6C [Re: GTXOnsfri] #460455
09/09/09 12:49 AM
09/09/09 12:49 AM
South Florida
goalsetterpk Offline
South Florida
I am in the same boat, need the RH/Passenger rear panel but understood the repops were abandoned shortly after release.
Laysons made an effort but when I called last month no more. I understood the repops were a poor quality fiberglass deal.
Guess we are both stuck looking for used OEM on EBay?
cell phone 561 315 5576
Re: 68 GTX convertible colors, S6C [Re: Mike Mancini] #460456
09/09/09 12:53 AM
09/09/09 12:53 AM
South Florida
South Florida
THANKS for your fantastic picture would you have the paint codes for both those two whites, please? The White Pearl looks dynamite. Whatever manufacture you used looks fine to me.
Re: 68 GTX convertible colors, S6C [Re: goalsetterpk] #460457
09/09/09 05:40 PM
09/09/09 05:40 PM
Mass
Mass
The pearl is a special mix which I matched to a mint original panel. I do sell the mix if you are interested you can order from us.
Michael L. Mancini
65 Foliage Drive
N. Kingstown, RI
Re: 68 GTX convertible colors, S6C [Re: Mike Mancini] #460458
09/09/09 06:54 PM
09/09/09 06:54 PM
South Florida
South Florida
Thanks Mike I'll PM you to buy a quart next week.
Re: 68 GTX convertible colors, S6C [Re: GTXOnsfri] #460459
09/13/09 01:48 PM
09/13/09 01:48 PM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
this is almost exactly like my dads car. cept' his has black interior. 440 4speed. the qq1 is an interesting color
