Re: BARRELCUDA: Weekends over BACK 2 WORK
[Re: anlauto]
#45951
10/10/07 08:33 PM
10/10/07 08:33 PM
Posts: 8,341 Crook County, ILL
Mastershake340
Crook County, ILL
In '71 they went with a sort of "one size fits all" disc brake master cylinder p/n 3461176 (B, C,E, and some light trucks). A bodies used an almost identical master cylinder (casting number and bore diameter same). The only exception I know of is the p/n 2944476 which was carried over from '70 for disc brake hemi cars. The 2229171 casting number is the p/n 2944453 which is '70 e body disc brakes only. You can look on the fender side of the casting of your '9171 for a date code, the upper line will include "9175" which is some sort of assembly line or plant code, and the line below it will be the date code. "9 324" for example would be the 324th day of '69. Anyway, check that number and see if it seems at all close to late summer/early fall of '70 to get an idea of if there is any hint that one could be the original for your car. I've never seen a '171 on a '71 E body, so I doubt any were built with them. But as they say with Mopars, anything was possible I guess! ![](/ubbthreads/images/graemlins/scope.gif)
[Re: Mastershake340]
#45952
10/10/07 08:53 PM
10/10/07 08:53 PM
I love it.I want to do this with everything I own.My 'Cuda.My Charger.My S10! and cars I don't even own yet!
[Re: shakerjoe]
#45955
10/11/07 12:09 AM
10/11/07 12:09 AM
Posts: 1,183 eganville ont
440beep
eganville ont
on my 71 gtx oct 10 1970 disc brake master cylinder is casting number is 346187 ![](/ubbthreads/images/graemlins/beer.gif)
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: BARRELCUDA: Day 11 UPDATE !
[Re: anlauto]
#45957
10/11/07 06:51 PM
10/11/07 06:51 PM
Posts: 11,854 Georgetown Ontario Canada
anlauto
Ok...So Brewers ![](/ubbthreads/images/graemlins/thumbs.gif) came through with the correct flywheel in record time and UPS was kind enough to only add on another $85 to the cost ![](/ubbthreads/images/graemlins/rant.gif) But here it goes...The engine transmission were mated ![](/ubbthreads/images/graemlins/smoke.gif)
CHECK OUT MY NEW WEB SITE !
[Re: fastback383]
#45968
10/11/07 08:22 PM
10/11/07 08:22 PM
Wow---i really cannot believe how awesome of a job you are doing! Its just amazing, simply amazing Allan! Would you like to do my Charger for me!? ![](/ubbthreads/images/graemlins/laugh2.gif)
#45969
10/11/07 08:57 PM
10/11/07 08:57 PM
Alan, why didn't you paint the bellhousing?
