Still to HOT help. #459185
09/04/09 04:50 PM
09/04/09 04:50 PM
Indiana
rapid67rt Offline OP
Indiana
A-body 493 stroker had a real bad overheating problem. Changed from a 22" to 26" aflo performance series radiator, perma cool electric fan 2950 cfm. I'm running a meziere electric waterpump. I went with the zerex o5 mixed 50/50 and waterweter. This is on the street now... 185-190 running down the road. stoplight's 200-210+. It seems to recover once I begin to move back to 185-190. I feel this is still to hot? Gottta be enough radiator? Go back to a stock water pump? 180 thermostat from napa.
Re: Still to HOT help. [Re: rapid67rt] #459186
09/04/09 04:53 PM
09/04/09 04:53 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
You could possibly have air in the system. Did you drill a 1/8" hole in the thermostat to bleed air?
Re: Still to HOT help. [Re: rapid67rt] #459187
09/04/09 05:00 PM
09/04/09 05:00 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Do you have a fan shroud?
Re: Still to HOT help. [Re: YO7_A66] #459188
09/04/09 05:07 PM
09/04/09 05:07 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
If it were mine I would suspect the electric WP. It wouldn't be too hard to swap back to the old one and try it.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Still to HOT help. [Re: rapid67rt] #459189
09/04/09 05:18 PM
09/04/09 05:18 PM
Indiana
Indiana
No shroud, never heard of drilling a 1/8 hole in thermostat but I'll give it a try. Where can i pick up a aftermarket shroud?
Re: Still to HOT help. [Re: rapid67rt] #459190
09/04/09 06:09 PM
09/04/09 06:09 PM
(At idle) either the elec pump is not moving the water fast enough or not enough airflow thru the rad or a combination of both. Unless elec WP's are inadequate at idle(never used one) I'd suspect (lack of) airflow. Need a shroud and a properly spaced thermal clutch fan
Re: Still to HOT help. [Re: RapidRobert] #459191
09/04/09 06:18 PM
09/04/09 06:18 PM
Simi Valley, CA
MoparJ Offline
MoparJ  Offline
Simi Valley, CA
All things considered, 185-190 running is perfect. 200 at speed on really hot days isnt even that bad.
200-210 on warm to hot days at idle or at a stop light isnt really considered overly hot as well. Some like to keep it cooler, but those temps are ok and not causing any damage or issues. Its when temps get over 220 that I would begin to get a tad concerned.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
Re: Still to HOT help. [Re: rapid67rt] #459192
09/04/09 07:16 PM
09/04/09 07:16 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
That tells you it's an air flow problem. I had to add a pusher fan on the front side of the radiator because of the same problem. I offset the two fans to different sides of the radiator. You could try a shroud but that might not be enough.
Puller -
Pusher -
Re: Still to HOT help. [Re: Lefty] #459193
09/05/09 07:25 AM
09/05/09 07:25 AM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
210 is OK. Forget all the fancy stuff. Run stock clutch fan, shroud etc. 180 SuperStat from Napa.
Re: Still to HOT help. [Re: DennisH ] #459194
09/05/09 07:38 AM
09/05/09 07:38 AM
Coram, NY
Pool Fixer Offline
Pool Fixer  Offline
Coram, NY
Unless you are running an OE electric fan or a SPAL, i don't think you are getting near that cfm you posted. I'd spend a few bucks on a nice set of SPAL fans or use one of the many OE fans discussed on moparts in other threads. If you searched, you would find many options. guys are running everything from minivan fans to lincoln mark VIII fans to mercedes fans....oe's seem to be really good fans.
edit...what about putting one of those square house fans in front of the car idling in your driveway to test. If it stays cool, you know you need more airflow. At worst you could eliminate airflow as the culprit
