John, I looked and same illustrations are used on both decals. Now here's the trivia that might win you a beer sometime. The differences I see (assuming these two are correct?) are:
1. Overall size of the label with the '68 (on left) being larger.
2. The words "Remove ignition key" are not on the '69 jack instruction label in "Step (2)"
3. Step (5) has error in wording, states to "Loosen wheel
BOLTS one turn" (there's the beer winner, they are lug NUTS not bolts
![](/ubbthreads/images/graemlins/beer.gif)
4. Step (8) Again makes the wording error and refers to them as BOLTS
5. Step (9) Makes the wording error one more time and refers to them a wheel BOLTS.
6. Part number of label OF COURSE is different.
The '69 label is smaller in overall size, has the words "Remove ignition key" deleted, the word bolts is changed to NUTS and a new part number.
You can see the word bolts on the above original jack instruction label, I'll post an A12 '69 label to see if it does read nuts and if it's missing "remove ignition key" later.
MikeR
