Anybody use large dia. pulleys on your alternator? #458785
09/03/09 11:44 PM
09/03/09 11:44 PM
Iowa
Rodder Offline OP
Rodder  Offline OP
Iowa
I have tried tried two different pulleys for racing. One spit off the end of the shaft and went down the track, and the other won't keep the belt on. I gave up on the last one because I could not line it up to keep the belt on no matter what I tried. Do they really give you any performance gain?
Re: Anybody use large dia. pulleys on your alternator? [Re: Rodder] #458786
09/04/09 09:44 AM
09/04/09 09:44 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Performance gain? Slight. Sounds like you have some alignment issues.
Re: Anybody use large dia. pulleys on your alternator? [Re: Rodder] #458787
09/04/09 09:55 AM
09/04/09 09:55 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Rather than just slow it down (reduced charging at all speeds), the usual method is to keep the same ratio so it charges at idle, and kill the current to the fields under WOT with a micro-switch and relay so there is no drag during the run except the belt friction.
Boffin Emeritus
Re: Anybody use large dia. pulleys on your alternator? [Re: polyspheric] #458788
09/04/09 11:00 AM
09/04/09 11:00 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
Take 10 pounds out instead.
Re: Anybody use large dia. pulleys on your alternator? [Re: Rodder] #458789
09/04/09 11:11 AM
09/04/09 11:11 AM
Az
Crizila Offline
Crizila  Offline
Az
Moroso sells a 5" deep groove press on pulley.
Fastest 300
Re: Anybody use large dia. pulleys on your alternator? [Re: Rodder] #458790
09/04/09 11:15 AM
09/04/09 11:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I make my own pulleys for my stuff and yes I do make
the alt pulley larger but not alot due to the groove
I put into them... its deeper so it has a lesser chance
to throw the belt... I use to have a switch to turn
off the field but found it didnt make any difference
on my car so when I replaced my switch panel I didnt
do that switch
Re: Anybody use large dia. pulleys on your alternator? [Re: Crizila] #458791
09/04/09 12:06 PM
09/04/09 12:06 PM
NW Indiana USA
727specialist Offline
NW Indiana USA
I use that same pulley. I kept frying bearings with the high RPMs. I haven't had anymore problems with the bearings since using it.
