5.7 hemi swap power steering pump #458335
09/03/09 02:36 PM
09/03/09 02:36 PM
Memphis, MO
X
xpsyclonex2002 Offline OP
X
Memphis, MO
I am swapping in the hemi into a 66 coronet. I know that I need a 950 psi GM power steering pump to work with our power steering box. I know that S&P sells them. Who knows the GM part number for this pump?
Re: 5.7 hemi swap power steering pump [Re: xpsyclonex2002] #458336
09/03/09 07:27 PM
09/03/09 07:27 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If you have a good/preferably new pitman seal on the steering box a stock 5.7 hemi pump will work just fine. A little extra length of line (a foot or two extra) on the pressure side and a factory LX or LC power steering cooler on the return and it'll work great.
