Mopar Techs, 2003 Neon question ??? #456731
09/01/09 07:47 PM
09/01/09 07:47 PM
SW FL
dodgedartgt Offline OP
SW FL
Hi guys,
My 2.0l 5spd Neon has started to "stumble", surge, shudder, not sure exactly what word to use to descride it.
I can either be at a steady state cruise, or accelerating and all of a sudden, it seems to momentarily fall on its face, then as quickly, pick back up.
Sometimes I have to shove in the clutch, maybe downshift and bring up the rpms, sometimes I can accelerate through it. There seems no consistancy as to when it will happen, very sporadic.
The only change I made was to install a K&N air filter I found in a Pick-n-Pull and left on a long high speed road trip. I normally drive the car very conservatively.
Removed the K&N and installed a brand new paper filter after the trip. I also removed the throttle body and wiped clean with a soft cotton cloth (diaper material).
BTW, the computer is not throwing any codes... at all!
Are there any TSB's for this discrepancy and/or what kind of suggestions do you guys have? Is there someway to monitor while I'm driving?
Thnx in advance,
Mikey Bynum
Re: Mopar Techs, 2003 Neon question ??? [Re: dodgedartgt] #456732
09/01/09 08:59 PM
09/01/09 08:59 PM
Kitchener, Ontario, Canada
moparrlz Offline
super street
moparrlz  Offline
super street
Check to see if the valve cover oil seals are leaking. pull each plug wire off, and see if there is any oil around any of the spark plugs. I had this happen on my 98 Neon.
Fred
Re: Mopar Techs, 2003 Neon question ??? [Re: moparrlz] #456733
09/01/09 11:25 PM
09/01/09 11:25 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Any cut or hole in the hose between the intake and throttle body? Mil on?
Re: Mopar Techs, 2003 Neon question ??? [Re: SALEM1912] #456734
09/02/09 09:23 AM
09/02/09 09:23 AM
SW FL
SW FL
Thnx guys, I'll have a look, though I haven't seen anything out of the ordinary.
SALEM1912, what does "Mil on" mean?
Okay, are there any other suggestions?
Thnx, Mikey Bynum
Re: Mopar Techs, 2003 Neon question ??? [Re: dodgedartgt] #456735
09/05/09 10:10 AM
09/05/09 10:10 AM
SW FL
SW FL
BTTT
Any Mopar Techs who have experienced this?
All of a sudden the phrase "bucking and snorting" comes to mind when this happens.
I need more ideas, please.
Thnx, Mikey Bynum
Re: Mopar Techs, 2003 Neon question ??? [Re: dodgedartgt] #456736
09/05/09 12:15 PM
09/05/09 12:15 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Only problem we ever have with my wife's 00 Neon is that it eats spark plugs every two years. I would check the plugs, wires.
Sheldon
Re: Mopar Techs, 2003 Neon question ??? [Re: RUNCHARGER] #456737
09/05/09 04:46 PM
09/05/09 04:46 PM
Ridley Park, Pa.
69MOPE Offline
super gas
69MOPE  Offline
super gas
Ridley Park, Pa.
If the spark plug wires have more than 25000 miles on them replace them and the plugs.
Re: Mopar Techs, 2003 Neon question ??? [Re: dodgedartgt] #456738
09/05/09 09:45 PM
09/05/09 09:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mil on means is the check engine light on, i.e. throwing a code, which you answered in your original posting.
Neons eat plugs and wires, that is where I would start. It's probably the most common cause of what you see. If that isn't it then we can dig into more esoteric stuff. But a basic once over looking for loose connections, unplugged vacuum lines, etc. wouldn't hurt.
As for the K&N, I would put it back in the junkyard myself. There is a reason it flows more air, cause it filters less. Oiled cotton or not, if oiled cotton was so great how come HEPA filters are not oiled cotton? Cause oiled cotton doesn't filter as well.
Don't be the exception.
