Re: Cal Tracs and SS springs work or not
[Re: correctdirection]
#456044
08/31/09 11:03 PM
08/31/09 11:03 PM
Posts: 852 Georgetown, TX
sc4579
Georgetown, TX
Been running them on my Dart Sport with SS springs for 4 years and car consistently hooks up, even on bad tracks. But, I am not putting a lot of power to the ground. I only run 7.40's in the 1/8. They may not work with more power I am not sure.
2023 Challenger Scat Pack 1320 2016 Jeep Renegade
#456046
09/01/09 01:17 AM
09/01/09 01:17 AM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
My car has never hooked as well with monos and 22" cal tracs as it did ss springs and cal tracs ss and cal tracs below ![](/ubbthreads/images/graemlins/Twocents.gif)
#456047
09/01/09 08:47 AM
09/01/09 08:47 AM
Posts: 686 PA
ajcasini
PA
60' 1.47-1.52 depending on track. 6.97-7.00 1/8 mile. 500 cid 8" coan conv. 4.56 gears. 29.5x11.5 phoenix
This was nearly the same setup and ET of my car when I first put on the cal tracs and they worked great. I had the Cal tracs with SS Springs and a set of monroe 50/50 shocks. Never spun a tire. 60' was around 1.44 - 1.47 depending on the track.
[Re: ajcasini]
#456048
09/01/09 10:40 AM
09/01/09 10:40 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I am not a big fan of using both. We have found that it is too violent and you can't tighten the shocks enough for control. I like the mono leaf beacause it alows the bar and the shocks to do all the work. The spring is just to hold up the car and go for the ride.
JAKES AUTOMOTIVE
[Re: JAKE68]
#456049
09/01/09 11:24 AM
09/01/09 11:24 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
I never ran both but always heard you shouldn`t. My 60 fts were actually better with the S/S springs 1.40 best with 1.42-1.44 average when I was running mid-10s. When I went to the CalTrac/monoleaf setup my 60fts got slower 1.44-1.46 but the car didn`t rise as much in the rear and the 60fts were more consistent. All with 10.5x29.5 Hoosier slicks. Now the car is setup to run 11.50 and my 60fts are 1.53-1.55 with Hoosier QTPs 29x11.50.
[Re: 11secdart]
#456050
09/01/09 12:36 PM
09/01/09 12:36 PM
Posts: 2,586 Illinois, Indiana, Louisiana
ProStDodge
Answer to the question - SS springs are not optimum for cal-trac's but will work. The principle of the cal-trac is to move the IC (Instant center) of car farther forward on launch. The IC is the effective lifting point of the suspension system as the rear end rotates. The super stock spring has a stiff front segment which is designed to act like a ladder bar and lift upward just a little in front of the spring perch. This will lift the back end of the car, since the perch is not very far forward on the body. The cal-trac bar will try to move this lifting force (IC) a little further forward, effectively trying to pickup more of the car. The more of the car you lift, the more downward force there is on the tires. The cal-trac system with a softer spring will allow for a little more roll rotation of the rear end, resulting the some wrap of the front spring segment. This gives the cal-trac bar a better force vector to effectively move the IC even farther forward. Thereby picking up more of the car on launch, providing additional downforce on the tires. IF there is not enough front end travel (5-inches is recommended) it could limit the amount of roll rotation of the body, reducing the continuous downforce on the back tires. In other words if the motor is not strong enough to keep lifting, the body will drop the front back down too quickly and remove the rear tire downforce. In that case, you would move the cal-trac bar to the top hole, so the motor does not have to pick up as much of the car. The "magic" number of 5-inches of front end travel comes straight from john Calvert. Less can cause the tires to bite on initial hit, but spin slightly a few feet off the starting line. More than 5-inches does not seem to help any more than the first 5-inches. To measure this, check the height of the front wheel lip. then jack the car from the center of the k-frame till the front tire starts to come up off the ground. Remeasure the wheel lip height. If there is not five inches you will need to loosen the torsion bar settings (both sides the same amount to keep the corner weights similar) to lower the front end. Taller may be needed to bring the ride height back up. ![](/ubbthreads/images/graemlins/drive.gif)
#456051
09/01/09 12:55 PM
09/01/09 12:55 PM
ProStDodge
Trying to get drivers rear to stop unloading on launch.
I am wondering about this statement. The normal roll rotation of the rear end is to the driver side, generally planting the left tire harder than the right tire. As the left tire had more load on it, it tends to drive harder, forcing the car to the right. Even an open track rear end will spin the right tire before the left.
If you have too much "pre-load" (additional weight) on the right tire, it could over-come the roll rotation and try to plant the right tire harder, driving the car to the left. If that is truly the case, you could soften the right rear shock or raise the right front corner of the car with the torsion bar to adjust the weight transfer of the car more to the left rear tire.
You could also raise the tire pressure in the right tire to give it less of a contact patch, effectively giving the left tire more traction.
HOWEVER. Unless you have done something to really load the right rear of the car. I am wondering if there may be some other problem in the suspension system which would create this problem. Rarely will a leaf spring car try to spin the left tire harder than the right. A thorough inspection of the front a rear suspension should be done. Try switching the rear shocks from one side to the other - one may be "bad".
Try bouncing the car at all four corners to see if there is a bind in the suspension travel (easier done if the shocks are off).
Scott
[Re: Dodgem]
#456053
09/01/09 07:01 PM
09/01/09 07:01 PM
Posts: 654 ohio
dbran451
ohio
I have been running them for four or five years that way I did make one adjustment I took one leaf off each side to soften the spring as it now only carries the car and is not used to help traction
[Re: Lil Wedge]
#456056
09/02/09 03:16 AM
09/02/09 03:16 AM
ProStDodge
No - The short front segment on the Mono's should not be an issue, they are designed to flex. From the pics, you definitely get the front end up! NICE! ![](/ubbthreads/images/graemlins/bow.gif) But, do you have the 5" of front end travel BEFORE the wheels carry?? If not, it could be limiting your front-to-rear body roll/weight transfer when you don't have excessive pre-load. By the way - nice level wheel stand too! Means the pre-load you do have it set about right from side-to-side! What rear tires are you running?? They look really large in the pics.
[Re: ProStDodge]
#456057
09/02/09 07:24 AM
09/02/09 07:24 AM
Posts: 39 south dakota
correctdirection
south dakota
Maybe saying drivers rear is unloading is not the right way to say what is happening. I was told the drivers rear is actually coming off the ground on launch. I've tried switching shocks from side to side no change. Pinion angle is 7 degrees down. I will check front end travel to see where it is at. Just cant figure out why car is so violant on launch. I will try to post some pictures in a bit. Thanks for all the help.
#456058
09/02/09 11:12 AM
09/02/09 11:12 AM
ProStDodge
Maybe saying drivers rear is unloading is not the right way to say what is happening. I was told the drivers rear is actually coming off the ground on launch. I've tried switching shocks from side to side no change. Pinion angle is 7 degrees down. I will check front end travel to see where it is at. Just cant figure out why car is so violent on launch. I will try to post some pictures in a bit. Thanks for all the help.
What tire are you using? To unload enough to jump off the ground I would think you may have worn out the sidewalls on the tires, and run them too low on air pressure, allowing the tread to "bunch" or roll up, causing an upforce. With a double adjustable shock you could stiffen both the compression and the extension. Stiffing the extension will slow the body rise, so as not to hit the tires as hard. Stiffening the compression will help control the tires if they try to unload.
However my best guess is still the front end travel (do you have adjustable shocks on the front or 90-10's??)
[Re: ProStDodge]
#456059
09/02/09 11:17 AM
09/02/09 11:17 AM
Posts: 2,763 Walton's Mountain, Pa
Steve1118
Admittedly, it has been a long time since I checked the rules for Stock Eliminator....but I've always understood them to be that they could not add or subtract leaves in their springs....they had to remain stock.
That being said, none of those guys could be using the monoleaf, they'd have to use the Cal Tracs with the stock spring setup. Is this true, or are they doing something else to help make them work?
"Old age and treachery trumps youth and enthusiasm, every time!" East Central Director / Chrysler Power Magazine www.reasbeckracing.webs.com
