Re: Code P0405
[Re: PC-CHARGER]
#456012
09/01/09 06:48 AM
09/01/09 06:48 AM
Posts: 320 Dallas, TX
71_Demon
Dallas, TX
Every EGR code I have ever had on those has been just the valave. Propably done two hundred of them. I'd run a continuty test from the connector to the pcm just to make sure though.
'71 Demon 383 auto
'12 Ram 2500 6.7 Diesel
Re: Code P0405
[Re: PC-CHARGER]
#456014
09/01/09 02:08 PM
09/01/09 02:08 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
They have a wierd egr on those.You get the valve and the egr together.I check for vacuum to the valve then pull vacuum on the egr.If it has them it needs replaced.99% of the time it needs replaced.Rocky
Chrysler Firepower
Re: Code P0405 :UPDATE:
[Re: PC-CHARGER]
#456017
09/25/09 03:43 PM
09/25/09 03:43 PM
therocks
Niles , Ohio
I agree its more than likely the EGR.I believe even at the dealer they are cheap like 50 bucks or so and they have a vacuum part with them.I probally changed 50 at work.Rocky
Chrysler Firepower
