Re: Recommendation on dropping in a engine/trans
[Re: 440_ci]
#455970
08/31/09 08:54 PM
08/31/09 08:54 PM
RapidRobert
eng/trans together. I swear by having the steering box,center link,idler arm all OUT. Use the tilter & replace the crank handle w a welded on nut to use your air ratchet. Level smooth concrete floor, a helper,blankets, several hundred lbs of cement blocks/weights on the cherry picker, make sure the chain/bolts/large washers are CORRECT for what you need.
[Re: 440_ci]
#455972
08/31/09 09:14 PM
08/31/09 09:14 PM
Posts: 182 NW of Indy
Thackdaddy
NW of Indy
Thanks alot for the responses, when you said you dont jack up the car you mean you just leave the car completely flat on the ground the whole time? or just until the engine is in? This is the only difference in the way i have done other engines and am thinking if this is why i run into these engine mount problems every time.
Completely flat the whole time, two things though.
First air the tires up and second, I am thin.
[Re: 440_ci]
#455973
08/31/09 09:19 PM
08/31/09 09:19 PM
Posts: 15,487 Florida
scratchnfotraction
man,I do it the hard way or not at all dirt yard and a swing set engine/tranny combo stabbed in and push car forward,use a floor jack to catch the tail shaft of tranny and help guide it into place with out xmember and set the engine down on the mounts done it many times oh! I only jack the car/truck up to get under it..I am fat in the middle jack goes in long ways under front bumper and on plywood..if I gots it
[Re: 440_ci]
#455974
08/31/09 09:47 PM
08/31/09 09:47 PM
Posts: 1,639 Brandon, Ms
cornet684me
Brandon, Ms
i put my 440 in my 68'coronet in by myself , i bolted the 727 up to the motor and put both in one unit, i placed a blanket on the top of transmission to keep the trans from rubbing the paint,i hoisted with 1hand and moved the car with my other, i was in my garage on level ground and car rolled easy, i wld not recomend you do this by yourself, but you can do it by yourself, if you have patiences, you may have to jack up and down more than usual, i swear by putting both in as 1 unit and moving the car into the motor.
