E body frame rail splash shield #455394
08/31/09 09:59 AM
08/31/09 09:59 AM
cataclysm80 Offline OP
My car was missing all the splash shields that go on the bottom of the frame rails. I'm ordering the two K frame splash shields from A&M. I picked this shield up on Ebay.
Is this for auto trans cars only? Mini is an auto trans car and the shield lines up nicely with the holes in the frame rail.
Is there supposed to be another shield on the passenger frame rail? Just wondering if I'm missing anything else.
Tav
Re: E body frame rail splash shield [Re: cataclysm80] #455395
08/31/09 10:07 AM
08/31/09 10:07 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
For automatics and on driver's side only
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: E body frame rail splash shield [Re: cataclysm80] #455396
08/31/09 11:36 AM
08/31/09 11:36 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Here's what they looked like when they were new.
Re: E body frame rail splash shield [Re: HEMICUDA] #455397
08/31/09 02:57 PM
08/31/09 02:57 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Thats what mine looks like and none on the passenger side it was for the starter I guess?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: E body frame rail splash shield [Re: 340SIX] #455398
08/31/09 04:37 PM
08/31/09 04:37 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
Yes, it is a splash shield for the starter. I think they were on all cars, not just automatics. I'll look at my unrestored 4-spd when I get home.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: E body frame rail splash shield [Re: Erik] #455399
08/31/09 04:44 PM
08/31/09 04:44 PM
I was wondering why they wouldn't put it on a manual trans car. Was something in the way?
Tav
Re: E body frame rail splash shield [Re: cataclysm80] #455400
08/31/09 05:21 PM
08/31/09 05:21 PM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
I was wondering the same thing. I'm building a 440/6 clone that was an auto and is going to be a 4 speed. From my research it should't be on a 4 speed car......but why?
Re: E body frame rail splash shield [Re: 6pkaar] #455401
08/31/09 06:44 PM
08/31/09 06:44 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I think many were taken off by the first mechanic to work under the car, they are a pain to work around.
FWIW they cleanup very nicely with a pressure washer, mine looked worse than yours and this is what it looks like 3 years later sitting in my garage.
If you don't mind me asking, How were they held on? Screws or rivets?
If it is rivets, is this the right type of rivet?
If it is I have plenty I could send you some.
Re: E body frame rail splash shield [Re: Challenger 1] #455402
08/31/09 07:04 PM
08/31/09 07:04 PM
The holes in my frame are threaded. My original fasteners were missing along with the original shield, but from what I've gathered the shield was held on with machine screws, the same as used on the rear axle bumpers.
I think those rivets are for the two shields that go up by the K frame.
Tav
Re: E body frame rail splash shield [Re: cataclysm80] #455403
08/31/09 07:27 PM
08/31/09 07:27 PM
Stroudsburg, PA
Erik Offline
Erik  Offline
Stroudsburg, PA
I just looked at my car and it is not on it. All of the other splash sheilds are there, but that one is missing. I thought I pulled one off of a 340 4-spd car once. I could be wrong.
Re: E body frame rail splash shield [Re: Challenger 1] #455404
08/31/09 08:28 PM
08/31/09 08:28 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
also used on the E-body rear muffler shields
AND have been found on the 2 smaller ft shields on some cars in place of the rivets
Re: E body frame rail splash shield [Re: gtx6970] #455405
09/01/09 03:45 AM
09/01/09 03:45 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
The shields were bolted or riveted. The rivets’ would have been steel and not aluminum. The large shield that Tav originally posted about was on automatic cars only and was considered a starter shield on the drivers side frame rail only.
Re: E body frame rail splash shield [Re: 70440+6bbl] #455406
09/01/09 07:48 AM
09/01/09 07:48 AM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
Not used on 4spd .If I remember correctly,there exists a Chryler assembly drawing stating such. Drawings are NOT in Barry`s Hamtramck Registry archive any more . I had the same question some time ago and found the answer in the achive.
Re: E body frame rail splash shield [Re: HEMICUDA] #455407
09/01/09 08:32 AM
09/01/09 08:32 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
Whats the size of these screws ?
Are they suppose to be zinc or black phosphate ?
logan426
Re: E body frame rail splash shield [Re: MLR426] #455408
09/01/09 12:24 PM
09/01/09 12:24 PM
3
360six Offline
360six  Offline
1/4-20 w/ 3/8 head
should also have an anchor
Re: E body frame rail splash shield [Re: gtx6970] #455409
09/01/09 08:25 PM
09/01/09 08:25 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks Bill
Re: E body frame rail splash shield [Re: 360six] #455410
09/01/09 08:37 PM
09/01/09 08:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
1/4-20 w/ 3/8 head
They do, just can't see it in the picture
Re: E body frame rail splash shield [Re: gtx6970] #455411
09/03/09 09:15 AM
09/03/09 09:15 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
So I would assume if your using these screws for the front splash shields and heat shields on a 71 e-body you would need (6) OR (8) total ?
logan426
Re: E body frame rail splash shield [Re: gtx6970] #455412
09/03/09 09:36 AM
09/03/09 09:36 AM
Georgetown Ontario Canada
anlauto Offline
anlauto  Offline
Heat shields 3 each
Starter splash shield 4 ?
K frame shields 2 each
Rear axle rebound bumpers 2 each
I count 16
CHECK OUT MY NEW WEB SITE !
Re: E body frame rail splash shield [Re: anlauto] #455413
09/03/09 09:48 AM
09/03/09 09:48 AM
Cincinnati, Ohio
Cincinnati, Ohio
Heat shields 3 each
I count 16
Sounds about right.
