Z-Bar seems too long #454977
08/30/09 09:36 PM
08/30/09 09:36 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
my Z-bar seems too long! the stud that bolts to the frame wont slip into place! any suggestions?
69 superbee
Re: Z-Bar seems too long [Re: kieron_kohlmann] #454978
08/30/09 09:50 PM
08/30/09 09:50 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
was this car a factory 4 speed or converted? If converted they welded the Z bar bracket in the wrong place.
Re: Z-Bar seems too long [Re: Dougsmopars] #454979
08/30/09 11:51 PM
08/30/09 11:51 PM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
Are you running a lakewood bellhousing? Stock z-bar for your car should be 9" long.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: Z-Bar seems too long [Re: Dan Brewer] #454980
08/31/09 01:33 AM
08/31/09 01:33 AM
K
K
yes i am running a lakewood scatter shield on the car. do i need to trim the z bar down? it fit pretty tight when i had a bellhousing on it but now i need like 3/4 of an inch or so. the car was an original 4 speed car.
Re: Z-Bar seems too long [Re: kieron_kohlmann] #454981
08/31/09 08:18 AM
08/31/09 08:18 AM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
I had the same problem with a Lakewood scattershield on my 70 Charger RT that is an original 4speed car also. I measured and trimmed the Z bar to make it fit. Check and make sure your z bar is fairly level to your bracket and is not misaligned or you will have shifting problems.
Re: Z-Bar seems too long [Re: Blakcharger440] #454982
08/31/09 03:38 PM
08/31/09 03:38 PM
K
K
How much did you trim off and from which side?
Re: Z-Bar seems too long [Re: kieron_kohlmann] #454983
09/02/09 03:58 AM
09/02/09 03:58 AM
Spring Hill, Fl.
tecmopar Offline
tecmopar  Offline
Spring Hill, Fl.
Do you have the ball studs on the correct sides.
Re: Z-Bar seems too long [Re: kieron_kohlmann] #454984
09/02/09 09:26 AM
09/02/09 09:26 AM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
I had to cut .625" off of mine with the Lakewood setup. Cut the frame side to keep better geometry on the shorter cluch rod.
