Re: brake proportioning valve question
[Re: SSAAHemiFan]
#454850
08/30/09 07:41 PM
08/30/09 07:41 PM
Posts: 7,506 Az
Crizila
Az
Have a 64 plymouth with 4 wheel manual drums.
I am going to switch it to a dual master cylinder and was looking at repro proportioning valves vs. using just a splitter block.
I was under the impression that a factory proportioning valve not only regulates the fluid flow front to rear BUT it also would also divert the fluid and apply full brake pressure to the working circuit in case of a leak?. (Via a valve inside).
Is this true ??
No, not true. Thats the job of the "DUAL" master cylinder. The porportioning valve will only tell you if you have a failure ( and it won't tell you weather the failure is front of rear ) in the brake system through a shuttle valve located in the valve that turns on a light on the dash. The valve will not shut off the fluid to the side that is leaking. The peddle will get lower and lower as you continue to use the brakes. You will not loose brakes altogether though, as the non-leaking side will still work - with a very low peddle though.
Fastest 300
[Re: SSAAHemiFan]
#454851
08/30/09 07:42 PM
08/30/09 07:42 PM
Posts: 26,003 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Factory drum brakes don't use a prop valve, for the dual MC swap you only need the splitter.
[Re: SSAAHemiFan]
#454852
08/30/09 07:50 PM
08/30/09 07:50 PM
RapidRobert
IF you are having no proportioning problems now I'd suggest keeping your stock splitter block as you dont need a prop valve. unhook the rear brake line from the splitter, cap it(the splitter) w a brass inverted flare plug and run the line from the forward half of the new M/C to your now unconnected rear line & connect them with a brass double female inverted flare fitting & bleed em out.
[Re: Crizila]
#454854
09/01/09 04:03 PM
09/01/09 04:03 PM
John_Kunkel
Rio Linda, CA
Unless the MC has two different bore sizes, a dual MC puts out the same pressure front and rear as a single of the same bore.
