HOW MUCH POWER WILL A 904 TAKE ???????????????????????? #454659
08/30/09 03:25 PM
08/30/09 03:25 PM
alabama
mopars rule Offline OP
mopar addict
mopar addict
alabama
I was reading another post about 904 transmissions and was curious how much power a 904 will take with basic mods such as good clutches , sprag, bands. No exotic mods just the basics.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454660
08/30/09 03:39 PM
08/30/09 03:39 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
mine take's the abuse of around 600-625 hp with stock internal's but with oiling mod's, good clutchs/band's and a high gear drum multi spring retainer, ($100.00) using a transbrake.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: dartman366] #454661
08/30/09 04:05 PM
08/30/09 04:05 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Keep in mind the converter hub/snouts like to crack on 904's. I havent used one forever, but surely this is an issue that should be considered when thinking about a 904. Dont know if converter companies offer thicker walled hubs, but if they do, DEFINITLY get it. I bought a rather expensive converter for a 904 once and the hub broke off in the trans driving down the street, that was the last 904 for me.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: Hot 340] #454662
08/30/09 04:07 PM
08/30/09 04:07 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
There are thicker hubs availible for 904's, but you can also just change to the modern "flats" style pump gears. That seems to have cured the 904 snout problems.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: dizuster] #454663
08/30/09 04:19 PM
08/30/09 04:19 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Are the verts different from a 904 vs 727?
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: emarine01] #454664
08/30/09 04:25 PM
08/30/09 04:25 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
converters are different...
Tony
70 AARCuda Vitamin C
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: Hot 340] #454665
08/30/09 05:35 PM
08/30/09 05:35 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If you use a converter with a radius in the bottom of the pump drive slot's then it take's the crack prone stress point away, thicker hub's help also, I have seen my share of 727 converter drive's crack/ break in the same place also.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454666
08/30/09 06:21 PM
08/30/09 06:21 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
More than an 8 3/4"!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: S/ST 3040] #454667
08/30/09 06:32 PM
08/30/09 06:32 PM
alabama
mopar addict
mopar addict
alabama
Here we go again.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454668
08/30/09 06:37 PM
08/30/09 06:37 PM
S/ST 3040 Offline
S/ST 3040  Offline
Here we go again.
No, seriously.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454669
08/30/09 07:19 PM
08/30/09 07:19 PM
gregsdart Offline
gregsdart  Offline
The question would better be answered by finding out how much torque it will take. A hot 440 cube stroker making 600 + ft lbs of torque will not let it live near as long as a high rpm screamer, too much torque. Dartman 366 sounds like the guy to PM for a little history,,,,,,,,,,,,
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: gregsdart] #454670
08/31/09 05:11 PM
08/31/09 05:11 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
Most of those wheel standing stock Eliminator cars run 904's, i have heard of comp cars leaving at 9000 with a 904
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: 65signet] #454671
08/31/09 06:04 PM
08/31/09 06:04 PM
SWEET HOME ALABAMA
I
ITSDUSTA416 Offline
ITSDUSTA416  Offline
I
SWEET HOME ALABAMA
A 904 will take alot more than you think. My 904 broke the planetary after 3yrs of abuse,shifting from first to second gear in the air doesn't help much either.
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: S/ST 3040] #454672
08/31/09 09:02 PM
08/31/09 09:02 PM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
I like that!!!!!!!!
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454673
08/31/09 10:03 PM
08/31/09 10:03 PM
mid Ga.
W5Dart378 Offline
W5Dart378  Offline
mid Ga.
I think you're good to the 1.45 60ft range. I've always run an A&A input shaft though. I have broke every piece other than that, but that was after it got in the mid to low 1.30 range at 3200#.
It has been together for over 20 passes now,although all over 1.38 60fts, trying to get the 275 radial working.Should be good now though..
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: HOW MUCH POWER WILL A 904 TAKE ???????????????????????? [Re: mopars rule] #454674
09/01/09 08:42 AM
09/01/09 08:42 AM
johnnyp Offline
johnnyp  Offline
The 904 I have before we put in the alumium drums it had all stock parts other than being rollerized and high gear spring pack. Our 60 foots were 1.24 to 1.30 in a 3100 lbs car. The only thing we broke was direct drum broke after 600 pass on it. The shakt just broke out of the center of the drum. Has griner brake in trans too. Where I get parts machined for my trans. He say they are good for 1000hp with good parts in them. But didn't see much improvement in et with direct and high gear alumium drums.
