Do you think my hood scoop is a problem?
#454283
08/30/09 08:57 AM
08/30/09 08:57 AM
Posts: 4,055 Salina ks
572_dup2
Back On The Bumper!!
Salina ks
I have 6" cowl front carb has about 3/4 clearnace. Both carbs are maybe 2" from from top. Car does not pull like it should in second an high gear. Would it help if i had holes in front of scoop with an air pan?
Shawn Jennings
Re: Do you think my hood scoop is a problem?
[Re: 572_dup2]
#454284
08/30/09 09:25 AM
08/30/09 09:25 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The 2" isnt bad but I prefer more space... if you dont have a pan to seal off the carbs I would do that first. In a conventional scoop you would like the air horn about 3/4" below the bottom of the inlet of the scoop. A ideal entry is also preferred on each carb to help let the air make the 90% turn instead of a shear. If you can see in the cowl.... a little test is to tape a bunch of 2" long pieces of yarn in a bunch of places under the top of the cowl to see the air flow (cheap wind tunnel testing)
Post deleted by Defbob
[Re: MR_P_BODY]
#454285
08/30/09 11:31 AM
08/30/09 11:31 AM
#454286
08/30/09 11:33 AM
08/30/09 11:33 AM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
run it without the hood. i hate hoods
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Quicktree]
#454288
08/30/09 02:17 PM
08/30/09 02:17 PM
572_dup2
Salina ks
I did run with the hood off. It slowed down alot!
Shawn Jennings
[Re: 572_dup2]
#454289
08/30/09 03:38 PM
08/30/09 03:38 PM
#454290
08/30/09 03:47 PM
08/30/09 03:47 PM
Posts: 1,217 Wellington, FL
cudabunch
Wellington, FL
a total lack off air control which can reduce the airflow into the carbs. it acts like a siphon when crossing the carb openings
Put two K&N substacks on the carbs and that will take care of that problem.
[Re: Lil Wedge]
#454292
08/30/09 08:26 PM
08/30/09 08:26 PM
MR_P_BODY
I knew a guy who put a tunnel ram and on his 440 66 Dart and the car went from 10.90's to 10'70s and the hood got broken and He ran it without and put birdcatcher on it and went 10.50's. I figured it would slow about 2 tenths without hood but it went the other way. I still have trouble believing it. Must have trapped a lot of air under the hood?
I'm betting he would have gone a little quicker with the hood AND the bird catcher... I'm sure the bird catcher was directing the air much better
[Re: MR_P_BODY]
#454293
08/30/09 08:32 PM
08/30/09 08:32 PM
get rid of the cowl hood and put on a taller version of mine. then youll have the nostalgia look and get functionability. how bad did it run today? i got my all time best today in bad air.
[Re: 572_dup2]
#454294
08/30/09 09:32 PM
08/30/09 09:32 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Then ignore my other post..
Chris..
