race gas compared to E85 when converted #454044
08/29/09 11:19 PM
08/29/09 11:19 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
I have in another topic the problem i am having affording race gas on the streets in my Dart, one idea was to turn my motor into pump gas another just convert to E85.
I want to hear dyno #'s or track times from those guys that have tried this conversion......
was it worth it?
did you drop off allot ?
Thanks, Tim
The Legend
real 383 car now 440..
Re: race gas compared to E85 when converted [Re: 10sec340] #454045
08/29/09 11:26 PM
08/29/09 11:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
was it worth it?
Thanks, Tim
The Legend
My car didnt change AT ALL when I changed over to
E-85 and I havent turned up the timing yet... 14.1:1
compression
EDIT
Well worth the cost... you can make up the carb
difference in short order
Re: race gas compared to E85 when converted [Re: MR_P_BODY] #454046
08/30/09 08:20 AM
08/30/09 08:20 AM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
what about delivery fuel system ?
I have a magna fuel 500 pump and filter, 2port regulator .
Tim
Re: race gas compared to E85 when converted [Re: 10sec340] #454047
08/30/09 08:42 AM
08/30/09 08:42 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Tim
Your system need to pump at least 30% more volume over
gas... I use the same pump(pumps in my case, 2 Holley
black 150's) and a 4 port Mallory return style reg,
all these were used on my 1050 dom on my race gas
set up then I changed to a 1050 dom on E-85
Re: race gas compared to E85 when converted [Re: 10sec340] #454048
08/30/09 08:52 AM
08/30/09 08:52 AM
NC
440Jim Offline
440Jim  Offline
NC
was it worth it?
An easy YES Race gas $9.25/gallon, E85 $2.29/gallon. That pays for the conversion in short order. And E85 runs a little cooler. I changed more than just the carb, so my ET is not a direct fuel comparison. I estimate the E85 was 0.15 faster than gas, and methanol was another 0.15 faster than E85 in hot summer weather. The differences get smaller in colder air.
Re: race gas compared to E85 when converted [Re: 10sec340] #454049
08/30/09 08:55 AM
08/30/09 08:55 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
Now you've hot me thinking about it...Does anyone know if Holley 2300, 2-barrel sixpack carbs can be modified to have enough fuel flow capacity to run E85 and feed nearly 700 hp?
Re: race gas compared to E85 when converted [Re: jbc426] #454050
08/30/09 09:10 AM
08/30/09 09:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont see why not... your increasing the amount of
fuel not the air so if you have enough air flow you
would just need to increase the fuel volume by 30%
across the board... I dealt with Quick Fuel so you
might talk to them
Re: race gas compared to E85 when converted [Re: MR_P_BODY] #454051
08/30/09 09:36 AM
08/30/09 09:36 AM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
wish I would have gone this route before the summer, I would still have $$ left on my Sunoco Gas card !!!!!!!!!
I will be starting this conversion after the 8th(i have a track rental)
Cant wait !!!! Just dont tell anybody I went "Green" I hate tree huggers !!!
Re: race gas compared to E85 when converted [Re: 10sec340] #454052
08/30/09 11:19 AM
08/30/09 11:19 AM
Mr. Legend,Van Jones will love you for it! He's in charge of the "Green Energy" department! I also plan on making the switch,as soon as I can afford a new QFT 950,and get my E-Heads shaved for 12:1 compression. RandyB
Re: race gas compared to E85 when converted [Re: MR_P_BODY] #454053
08/30/09 08:32 PM
08/30/09 08:32 PM
West Coast, USA
West Coast, USA
might talk to them
Thanks for the tip. I found a 500 CFM E85 2bbl that's used for circle track racing on their website. It looks like with a little modification to the top of the carb it would be a bolt on replacement. It sure would be nice to have a trio of 500CFM E85 carbs under my shaker. I'm going to have to give them a call tomorrow to see how much that would set me back, and if they think it can be made to work on my application.
Re: race gas compared to E85 when converted [Re: jbc426] #454054
08/30/09 08:59 PM
08/30/09 08:59 PM
Gettysburg Pa
roadrunnerreds Offline
Gettysburg Pa
Mr Peabody should i do the volume check first with gas and then figure from that? Brad
Re: race gas compared to E85 when converted [Re: roadrunnerreds] #454055
08/30/09 09:05 PM
08/30/09 09:05 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Is there a problem with E85 ruining oil like is the case with methanol? S/F....Ken M
Re: race gas compared to E85 when converted [Re: EchoSixMike] #454056
08/30/09 09:36 PM
08/30/09 09:36 PM
Johnstown
69dart Offline
69dart  Offline
Johnstown
Well I'm finally going to try this E85 stuff. I stopped at Jegs and picked up the Quick Fuel conversion kit and an alcohol rebuild kit. So next Friday I'm going to hit test n tune and see how it works. I'm currently running a Holley 950 on a 400. I ran the numbers and as much as I race the E85 can save me $600 a season easily. I think the kits ran about $200 for the rebuild and E85 metering kit. My fuel pump is the only part thats iffy ...but I'm gonna try it and if the pump fails or isn't enough I'll replace it.
33 Plymouth Roadster - 383 - 5.90 1/8th 9.58 1/4
68 Dart - 340
66 Belvedere - 400
Windy Hollow Garage - https://www.youtube.com/@windyhollowgarage
Re: race gas compared to E85 when converted [Re: roadrunnerreds] #454057
08/30/09 09:45 PM
08/30/09 09:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Really you need to figure your engine consumption
as it is now then figure 30% more and see if your fuel
system will do at least that much
Re: race gas compared to E85 when converted [Re: EchoSixMike] #454058
08/30/09 09:51 PM
08/30/09 09:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No its nothing like meth... get get it warmed up
before your run... I get to about 185 degrees at the
end of my run each time and when I get back to my pit
spot and shut it down it back to about 165... I havent
seen hardly any oil contamination, I went last season
with 1 oil change mid season and it still looked good
Re: race gas compared to E85 when converted [Re: MR_P_BODY] #454059
08/30/09 10:11 PM
08/30/09 10:11 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
summit has kits for the dominator by quick fuel for only $270 !!
dam if thats all it takes I'll be set up right after the 8th track day !!!
I'm getting excited over here !!!!!!!!!
Re: race gas compared to E85 when converted [Re: 10sec340] #454060
08/30/09 10:42 PM
08/30/09 10:42 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I'm just waiting for an E85 pump to come to my area. Then I'll convert and maybe up my compression and camshaft for more power on cheap gas.
Re: race gas compared to E85 when converted [Re: ProSport] #454061
08/30/09 11:55 PM
08/30/09 11:55 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
If the dam ups shows up Mon. i should have my e-85 Dominator back from AED i sent it to them for the conversion and by next year we will have e-85 in our town, for now ill have to drive 127 miles to get it but it should be worth the effort.
Re: race gas compared to E85 when converted [Re: Cheatham] #454062
08/31/09 06:52 AM
08/31/09 06:52 AM
southwest Alabama
challenger73400 Offline
southwest Alabama
I just converted and thought I would try my carter mech pump.............no problems! 1/8th mile racing with a steath headed 470 running 660s in the full 1/8th.
Re: race gas compared to E85 when converted [Re: challenger73400] #454063
08/31/09 08:01 PM
08/31/09 08:01 PM
long beach,ny
10sec340 Offline OP
10sec340  Offline OP
long beach,ny
what about the concern that it's not always e85, some times it on 70 -75
or winterblends?
