Re: 727 tailshaft bushing
[Re: ohiodemon]
#453473
08/29/09 07:34 PM
08/29/09 07:34 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
1/8 inch is way to much, if you look at the bushing there will be 2 oil groves cut in it if it bad you wont see much if any of the groves.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: 451Mopar]
#453476
08/30/09 06:30 AM
08/30/09 06:30 AM
Posts: 75,095 A Banana Republic near you.
JohnRR
At least if you have to replace it, you do not have to remove the transmission, just the tail shaft section.
if you have the right tools you don't have to remove the tailshaft housing
[Re: JohnRR]
#453477
08/30/09 09:50 AM
08/30/09 09:50 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Cool, I did not know there was a tool that would remove the bushing with the output shaft in place. I just use a bushing driver, so the tail shaft has to be removed, which really is not a big deal.
