I rear-ended a truck and ever since I have the traction control cycling after initial start up.
After I start the car up and drop it into gear the little motor/ actuator cycles, I removed the ABS 30AMP fuse and it goes away so I narrowed it down to no slop in driveshaft or the wheel on spindle. any other ideas what it may be?
67 Ply. Belvedere II 2dr Hardtop 73 Dodge Charger SE 440+6 727 Dana 60 4.10 78 Chrysler Cordoba 400-4 727 9 1/4 3.21 1999 Dodge Diesel 2500 QuadCab Longbox 2004 Dodge Durango HEMI Limited
