ENGINE FINALLY DONE AND DYNO'D #452800
08/28/09 08:57 PM
08/28/09 08:57 PM
CHANDLER, AZ
512 VALIANT Offline OP
CHANDLER, AZ
400 block 4.40 bore 4.15 stroke 13:5 comp ported Victor heads and intake .690 solid roller 1.6 rockers 1050 dom.
702.4 hp @ 6300
662.6 tq @ 4800
pics to come later
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452801
08/28/09 09:46 PM
08/28/09 09:46 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Cool
What kind of ET's you looking for with it?
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452802
08/28/09 09:51 PM
08/28/09 09:51 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
702.4 hp @ 6300
662.6 tq @ 4800
pics to come later
HP seems kind of low, what rpm was it run up to?
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452803
08/28/09 11:23 PM
08/28/09 11:23 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Cool! What rod length?
702.4 hp @ 6300
662.6 tq @ 4800
pics to come later
Re: ENGINE FINALLY DONE AND DYNO'D [Re: moparguy7074] #452804
08/29/09 12:20 AM
08/29/09 12:20 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
702.4 hp @ 6300
662.6 tq @ 4800
pics to come later
Sounds strong to me....Cant wait to see pictures.
Re: ENGINE FINALLY DONE AND DYNO'D [Re: WILD BILL] #452805
08/29/09 12:37 PM
08/29/09 12:37 PM
CHANDLER, AZ
CHANDLER, AZ
Cool
I was originally going to run 10.90, but w/ the #'s it put out I'll have to slow it way down. the car wieghs less than 2800 w/ me and a the big block in it. After I get comfortable w/ the car I may try super gas ??? - The car is back halfed and has 32x14x15's and a 727 w/ brake and 4500 stall. Thx for the comments I read a lot of your posts.
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452806
08/29/09 12:42 PM
08/29/09 12:42 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
man that car is lite are your heads max wedge size ports? what did they flow?
.......cool car!
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452807
08/29/09 12:49 PM
08/29/09 12:49 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Great numbers should run well..NOW where are the dang pictures of the car
Re: ENGINE FINALLY DONE AND DYNO'D [Re: moparguy7074] #452808
08/29/09 12:57 PM
08/29/09 12:57 PM
CHANDLER, AZ
CHANDLER, AZ
702.4 hp @ 6300
662.6 tq @ 4800
pics to come later
6300 rpm @ 37 degrees timing #88 jets and it was 97 degrees ambient we were going to do a forth pull w/89's in it, but were not sure if we could duplicate correct air flow to justify it. Fuel per horsepower usage was dead on @ .397-.440 per # (you dyno guys will what I mean). ---- As far as low #'s!!!!!!! THIS IS NOT AN EXOTIC RACE ENGINE AT ALL. It is off the shelf parts - shaft rockers edlebrock heads etc. most (several engine builders) I spoke w/ assumed 650-675 including the shop the did the build. EVERYONE was very happy w/ the hp and the tq - they have done several builds similar and this was the highest producer yet by almost 35hp and 40tq. Shop owner said the heads came out REALLY NICE and that was the difference (335 @ .700). If I had B-1's or Indys I could see your point, but you could call Jegs or Herbert and probably have everthing in this engine shipped to your house w/ in a week.
Re: ENGINE FINALLY DONE AND DYNO'D [Re: Al_Alguire] #452809
08/29/09 01:32 PM
08/29/09 01:32 PM
CHANDLER, AZ
CHANDLER, AZ
Here they are
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452810
08/29/09 01:33 PM
08/29/09 01:33 PM
CHANDLER, AZ
CHANDLER, AZ
#2
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452811
08/29/09 01:34 PM
08/29/09 01:34 PM
CHANDLER, AZ
CHANDLER, AZ
#3
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452812
08/29/09 01:35 PM
08/29/09 01:35 PM
CHANDLER, AZ
CHANDLER, AZ
#4
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452813
08/29/09 01:51 PM
08/29/09 01:51 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
Very nice!!!!!!! So those are the standard port victors then? Thanks and later
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452814
08/29/09 01:52 PM
08/29/09 01:52 PM
gregsdart Offline
gregsdart  Offline
Very nice build. With that low rpm torque and hp, the car should really haul the mail.
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 70VcodeCoronetRT] #452815
08/29/09 03:01 PM
08/29/09 03:01 PM
CHANDLER, AZ
CHANDLER, AZ
yes standard port -- and to jwilli500 I will find out rod length - i'm drawing a blank right now sorry
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452816
08/29/09 04:24 PM
08/29/09 04:24 PM
Arizona
Chris'sBarracuda Offline
Arizona
Who did the dyno out here in AZ.?
Chris..
Re: ENGINE FINALLY DONE AND DYNO'D [Re: Chris'sBarracuda] #452817
08/29/09 05:28 PM
08/29/09 05:28 PM
Manassas, VA USA
Scamp451 Offline
Scamp451  Offline
Manassas, VA USA
That's a really nice car, I will be happy if my body work turns out half as straight as that! Looks great, love the color.
I see you are running a dragster pan, what front end do you have under there?
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 512 VALIANT] #452818
08/29/09 06:42 PM
08/29/09 06:42 PM
NC
440Jim Offline
440Jim  Offline
NC
Looks like it exceeded your expectations.
What is the duration of that cam? I am trying to see if the duration limited the peak hp rpm or the head flow. With that CR, you could put a bunch of duration in, but then it would like more converter stall speed.
Re: ENGINE FINALLY DONE AND DYNO'D [Re: 440Jim] #452819
08/29/09 06:46 PM
08/29/09 06:46 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Great power I can imagine the torque curve is very flat and useable from all RPM. is it a race only car? The reason I ask is if you've got so much torque you probably could put in a tighter more streetable converter and take better advantage of all that high port velocity grunt right off the line at 3200 instead of the vert side stepping most of it all until 4500. What gear is in the car?
Awesome power....hitting 700HP with a stock-ish 906 size port window is very impressive.
WIZE
In Car:
