weird happening with 4 speed
#452412
08/28/09 09:55 AM
08/28/09 09:55 AM
ok here is what is going on.i have a 4 speed in my bee.when you take off hard the clutch slips and then the weird thing happens it sounds like something swings and hits and then it pulls like a raped ape with no slippage at all.what in the world is doing this.we have had the car since 1979 and the clutch peddle never has came back on its own.and that is with new clutches throw out bearings pressure plates everything and it has be adjusted properly.what could do this is there anything under the dash to cause this that is where the sound comes from.thanks
Re: weird happening with 4 speed
[Re: 68KillerBee]
#452415
08/28/09 11:55 AM
08/28/09 11:55 AM
it has a hays street and strip combo with stock throwout bearing.i looked under dash and didnt see anything loose.its weird it slips and if you let off and nail it again you hear what ever hit and then its on like butter and no slippage.of course the pedal still doesnt return unless you pull up with your foot.
[Re: 68KillerBee]
#452417
08/28/09 06:16 PM
08/28/09 06:16 PM
so why would that cause it to act like something is swinging and then it dont slip.i understand that is more effort with that set up but i would not think it would cause it to do that.i didnt know if the huge spring under the dash would have anything to do with it or not.
[Re: PC-CHARGER]
#452421
08/29/09 12:12 AM
08/29/09 12:12 AM
thanks for all the suggestions.allthe linkages have been adjusted.the free play has been set and the pedal still wont come back.i dont know what the big spring under the dash does but i thought maybe it was weak.never thought about tranny mount or motor mount.it does not seem to slip under normal operation.
[Re: In_The_Pink]
#452423
08/29/09 06:46 AM
08/29/09 06:46 AM
no when i leave it out and jump on it hard thats when it slips let off of it without pushing clutch in i hear it swing and hit then jump back into it it doesnt slip i guess i have never really dumped it i guess i will have to try that
#452424
08/29/09 10:04 AM
08/29/09 10:04 AM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
Does it make this swing and jump nioce when the engine is not running and you operate the clutch?
[Re: In_The_Pink]
#452425
08/29/09 10:12 AM
08/29/09 10:12 AM
Posts: 10,220 Someplace you aren't
SomeCarGuy
Check the bushings. Then adjust until the pedal will return. It isn't right if it won't return. I got my first 4 speed car and the pedal had to be pulled up with my foot. Adjustment cured it.
I want my fair share
[Re: SomeCarGuy]
#452426
08/29/09 01:18 PM
08/29/09 01:18 PM
i have had brewers and a transmission shop adjust it and the pedal will still not return i have just got used to it but i know its not right and it does not do it when it is not running.
[Re: DAYCLONA]
#452429
08/29/09 10:15 PM
08/29/09 10:15 PM
brewers did nothing wrong he adjusted it same with the tranny shop and if i remember right it lasted about a day or so and then you have to pull it up with your foot.i remember replacing everything as far as new disc new pressure plate new throwout bearing and adjusted it and guess what still no return and yes the spring is on both the top and bottom.i even had a chrysler tech who was a 20 year pro make me longer adjusting rod to try and have more adjustment and same bs.i just what it to return without haveing to pull it up and for it not to act like that so i can whoop some chevy tail.
[Re: tecmopar]
#452431
08/30/09 10:34 AM
08/30/09 10:34 AM
thanks i know it will go to the floor because it has before when the rod fell off.but i have never tried it the other way.if it doesnt does that mean that the spring is bad or weak inside.i will try it and see what happens.
