Thanks for the replies, I’ll check into these things.
I know the brown wire isn’t for the washer fluid pump – that wire is wrapped up with the wire to the horn, and that part of the harness is barely visible in the pic at the bottom leading off towards the fender.
I’ll try to figure out if it could be the original tach wire – that’s a good possibility, also I wonder if my broadcast sheet would help me find out if the car originally had one of those electronic retard boxes. Would that have been an optional factory item?
I just noticed a post yesterday with a picture of what I think was one those things.
Looked like it had that bullet connector.
70mopes – I’m not sure if I have a later model alternator, but sure would appreciate any info as to how I can tell. Never really looked into it, but I do remember reading some info on here in the past about it.
If that brown terminal is supposed to connect to the alternator, any idea what it is for? Car starts, runs, and charges fine. As for the blue wire, I think you are saying the same as MoreParts, right?
Paul – no AC on my car now, but I can check the broadcast sheet and see if it was originally, to see if that is a possibility.
