SMALL BLOCK SINGLE TURBO #451948
08/27/09 04:50 PM
08/27/09 04:50 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
does anyone run a stock block 340 or 360 single or twin turbo ?just wanting to know how much boost the blocks can handle and what kind of times your getting out of them or....the 400 stock block,i know the haze has run a 400 block but don`t know if it was aftermarket,thanks for any replies
Re: SMALL BLOCK SINGLE TURBO [Re: mrart01] #451949
08/27/09 07:24 PM
08/27/09 07:24 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Indy low deck aluminum block on the haze I belive
Re: SMALL BLOCK SINGLE TURBO [Re: formula S] #451950
08/28/09 07:54 PM
08/28/09 07:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Aside from a hemi, the 400 is probably the strongest production block mopar built.
There is a guy (Trendz) that had/has a turbo'd 400 BB mopar in a G-body GM that has been in the 8's if I remember right. He posts on here sometimes, or over on the www.theturboforums.com
Re: SMALL BLOCK SINGLE TURBO [Re: dizuster] #451951
08/28/09 09:02 PM
08/28/09 09:02 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
I may have seen it on YouTube , I'll check into it thanks
Re: SMALL BLOCK SINGLE TURBO [Re: mrart01] #451952
08/28/09 09:08 PM
08/28/09 09:08 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
ran a 360 block cast crank 408 for a little while...never broke the block.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
