1.6 rockers worth the trouble/money?
#451735
08/27/09 11:54 AM
08/27/09 11:54 AM
Posts: 137 LI, new york
gmachinedart1
LI, new york
Im currently running harland sharp 1.5 rockers on my 360 with a racer brown [Email]254@50[/Email] 520 solid.Would it be worth the effort /money to swap the intakes with 1.6's?
thanx justin
Re: 1.6 rockers worth the trouble/money?
[Re: gmachinedart1]
#451738
08/27/09 12:12 PM
08/27/09 12:12 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
It depnds on your expextations, if your expecting the ratio change to pick your car up a bunch, more than .10, then you are probally not going to meet your expectations, I think. I have switch ratio in the past but I also switched heads so that is not a good comparision, hopefully some others with first hand experience will post there results
[Re: gmachinedart1]
#451740
08/27/09 12:26 PM
08/27/09 12:26 PM
Posts: 5,080 organ
maximum entropy
organ
it depends, if your heads flow A LOT more at 6.6% higher lift, and your intake/exhaust balance favors the exhaust, then you might see an improvement. it depends on a lot of things.
[Re: emarine01]
#451746
08/27/09 05:10 PM
08/27/09 05:10 PM
and the thing that most guys forget changing from 1:5 to 1:6 is pushrod clearances, you'll probably need to clearance the block and heads so they dont rub.meaning the motor has to come apart.
[Re: TS3303]
#451748
08/28/09 01:01 PM
08/28/09 01:01 PM
Posts: 4,213 New York
polyspheric
New York
reduction in mass being lifted
Boffin Emeritus
[Re: TS3303]
#451750
08/28/09 07:05 PM
08/28/09 07:05 PM
polyspheric
New York
Ah, yes... with the lobe adjusted for the same lift, thanks.
Actually, there's a tiny mass loss at the short lever when you change up the ratio as well, but not very significant.
Boffin Emeritus
[Re: gmachinedart1]
#451752
08/28/09 08:57 PM
08/28/09 08:57 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
thanx justin
For the Money a Cam swap is cheaper if you need more lift and duration! But say if you Needed new rockers anyways Id go with the 1.6,s
As far as the argument that the 1.6 ratio arms make more power because of less mass lift.
Not when useing the same cam as most will do in just trying a rocker swap.
"Even useing a smaller cam with the same Total overall lift the "more power because of less mass lift" doesnt hold water IMO "
The mass remains the same, and the Leverage against the springs pressures is reduced requiring even more force to lift the valvetrain from the cam and lobes point of view.
The increase in power from the switch will come mostly from the increase in duration at the higher lifts that the 1.6,s will give,and some, very little from the increased lift.!!
Unless you have some huge ask cam to begin with, mike
[Re: Sport440]
#451753
08/28/09 10:45 PM
08/28/09 10:45 PM
Posts: 1,532 off the grid
340B5
off the grid
Valve train weight aside, what about the fact that exhaust pressures are in the 1000's of psi and you have about 14 psi atmospheric pressure equalizing into a cylinder on the intake stroke. It would seem using a 1.6 rocker on the intake would help fill the cylinders, especially on a short stroke engine.
Yeah, it's got a smallblock.
