Re: Indybrocks vs. W2's
[Re: gmachinedart1]
#451686
08/27/09 11:57 AM
08/27/09 11:57 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Pros: 1. Edelbrocks are lighter (handling) 2. Edelbrocks have less CSA (important for accellerating from the corners) 3. Requires fewer specialty component (intake, headers) 4. Easier to fix after head damage Cons: 1. Have to use INDY's rocker arms 2.
[Re: S/ST 3040]
#451689
08/27/09 01:30 PM
08/27/09 01:30 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Do you plan on running a solid roller cam, or FT? I like the edelbrock heads for road race because as mentioned there are alot of pro's, plus the valvetrain is less likely to be a problem over the highly offset W2 stuff.
How much power do you want/need? What are the rpm ranges you'll run (lowest and highest)? How heavy is this car? I've seen short stroke engines kill bigger stroke stuff if done right.
Brian Hafliger
[Re: S/ST 3040]
#451690
08/27/09 02:08 PM
08/27/09 02:08 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
most pro porters only see 10-15 CFM of additional peak flow with the indybrocks, IIRC. personally, I'd go max ported standard eddies, or maybe mag eddies for the smaller chamber and cheaper rocker alternatives.
if I were looking for a relocated pushrod aluminum head, I think I'd go large port commandos. fully ported they're about as good as W2's, and have a small 53cc or so chamber.
[Re: patrick]
#451691
08/27/09 02:54 PM
08/27/09 02:54 PM
Posts: 11,729 Portage,michigan
B3422W5
Portage,michigan
Good info...but, the last thing i would do is go with the large port commando's, they are expensive, need guide work,(3/8) and from what i have seen arent even"about as good" as a W2. I would say a w2 is "about as good" as a w5 though.The large port commando's seem only marginally better than an edddie, at way more cost.
For what this guy seems to want to do, cost, availability, etc, standard eddies seem the way to go.
[Re: RyanJ]
#451693
08/27/09 03:03 PM
08/27/09 03:03 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
There isn't much extra flow available removing the pushrod pinch, but there is power available by doing this! You help reduce the smallest area in the entire intake tract, and thereby you help keep inertia up during the intake cycle.
It helps topend HP and HP past HP peak, but I've also seen it add TQ below and above TQ peak! For a true 7200rpm, I would use the Indybrock's hands down.
Brian Hafliger
[Re: S/ST 3040]
#451695
08/27/09 05:40 PM
08/27/09 05:40 PM
Posts: 31,082 Oregon
AndyF
Pros:
Cons:
I believe you can use any big block rocker arm set with the Indybrock heads. At least that is the way I understood it. If so then that means the rocker arms are very easy to find since anything from Crane nodulars to Harlands to RAS rockers should bolt on there. Maybe someone on here knows for sure?
[Re: AndyF]
#451696
08/27/09 06:33 PM
08/27/09 06:33 PM
Posts: 8,547 State College, PA
RyanJ
moparts member
moparts member
State College, PA
Pros:
Cons:
Look 3 posts up from yours LOL. The INDYBrock SB heads just use the INDY SR rocker arms, which are basically stock big block rockers, so yes pretty much any stock offset BB rocker would work. May have to fudge around with spacing & side clearance etc but should'nt be a big deal.
[Re: S/ST 3040]
#451698
08/27/09 08:02 PM
08/27/09 08:02 PM
Posts: 1,015 Down South
DaKuda
Down South
The crane Gold rockers work great on the Indybrocks
Here they are with the Indy SR rockers they supply.
[Re: DaKuda]
#451699
08/27/09 08:11 PM
08/27/09 08:11 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
my CNC'D Indybrocks flow 302@ .550 and 313@ .700 on Ryan's bench and seem to be making pretty good steam on my 416 considering the baby roller I have in the motor so far they have pushed my ride of 3000 lbs to 6.50 @ 105 in the 1/8 in terrible air of 95deg 90% humidity with rain on the horizon.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#451701
08/28/09 09:42 AM
08/28/09 09:42 AM
B3422W5
Portage,michigan
wow, i think i should get a set of those, they flow better than my w5's do
[Re: B3422W5]
#451702
08/28/09 10:15 AM
08/28/09 10:15 AM
S/ST 3040
Don............the never gets old, does it?
[Re: dusturbd340W5]
#451704
08/28/09 07:20 PM
08/28/09 07:20 PM
RyanJ
moparts member
moparts member
State College, PA
Just stating what is written on my flow sheet.I would think a set of GOOD w5's should flow more than 313.
His heads do flow more than 313 on my bench...... & his 9.80 ET's suggest they make more power than a typical INDYbrock & the timeslip, unlike #'s on a flowbench are all that matters.
