Re: 1970 Challenger door inserts
[Re: KISSAlien]
#451438
08/29/09 01:32 AM
08/29/09 01:32 AM
Posts: 4,165 Florida
cataclysm80
I have never seen actual Chrysler documentation that listed different woodgrain colors for E BODIES. I'd be very interested to see any mention.
While I can't point to any printed page, their is supporting evidence in every car, printed on the backside of the parts themselves.
I think that it was just a change in dye lots from the vendor. I do not think it was intentionally done.
While browsing through some of the engineering diagrams, I was a bit surprised to find instances where the 1971 cars were being designed before 1970 production began. Before 1970 production even began they were already planning changes for 71. Some diagrams with 1960's dates specified F series (1970) be one way, while G series (1971) be another. It's like both 70 & 71 cars were designed at the same time with the intent that they be different. Most people would think that the 71's were designed after the 70 model.
Hey Tav, do you have the actual numbers handy?
Sure, I just went out and grabbed a loose door insert and console top plate out of the shop. Here's the #'s right off the panels.
Here's all the #'s off the Door Insert first... 94200 (probably the vendor #) W-3415834-NP-3415842-BASE (maybe NP = Name Plate? which I'm thinking would be the Special Edition script.) 3415843-ASSY (just guessing this is the part # for the assembled SE Door Insert.)
W-3415606-MED-3415314-BASE (maybe MED = Medalion? which I'm thinking would be the triangular Dodge emblem. I'm thinking the BASEs would have different part #'s becuase the emblem holes are drilled differently?) 3415312-ASSY-KASHMIR 3509253-ASSY-AMERICAN (I think AMERICAN = American Walnut. Clearly there seems to be two different grains available, but so far no indication of which cars got which grain.)
Now for the console top plate. This is off of a slapstick car, and it's the 1970 only 4 hole version... 2879802-KASHMIR-F-SERIES (F series would be 1970) 94200 (apparently the same vendor as the door inserts) 3509155-AMERICAN-G-SERIES (G series would be 1971) 3509153-ASSY 508 ASSY FRONT
That makes it look like the intention was to have 1970 be Kashmir & 1971 be American Walnut. Does this sound correct? Tav
