Re: placement of the emission label '68 RR St Louis plant
[Re: pacifica]
#451100
08/26/09 08:16 PM
08/26/09 08:16 PM
Posts: 21,823 N.E. OHIO, USA
A12
N.E. OHIO, USA
Yeah, a photo from a '69 would help and I don't think they changed too much in a year. (I don't know what the heck I was reading before ![](/ubbthreads/images/graemlins/spank.gif) duh) MikeR
[Re: GMP440]
#451105
08/27/09 01:02 AM
08/27/09 01:02 AM
On my 68' Coronet it's located on the fender on the passenger side just forward of the washer bottle. It was a June 26 build date if that makes any difference.
mine is same.
[Re: A12]
#451107
08/27/09 09:43 AM
08/27/09 09:43 AM
Posts: 602 N.E.Ohio
pacifica
N.E.Ohio
" I don't think they changed too much in a year." "Famous last words" Do we know if being a hemi makes a difference on placement between 1968/1969? My SPD is 5/28/69
[Re: pacifica]
#451109
08/27/09 12:35 PM
08/27/09 12:35 PM
A12
N.E. OHIO, USA
" I don't think they changed too much in a year." "Famous last words" ![](/ubbthreads/images/graemlins/whistling.gif)
My SPD is 5/28/69
Yeah, I'm eating those words now eh? and yikes I never thought about it being on the passenger's side and what happens with a big block with A/C doesn't the metal tube run down the fender by the fender tag but I "think" I've seen the emission label there on a late December '68 built '69 Super Bee.......gota go check a photo, back later after I finish eating more words ![](/ubbthreads/images/graemlins/laugh2.gif)
MikeR
[Re: rocketresto]
#451114
08/28/09 12:23 PM
08/28/09 12:23 PM
A12
N.E. OHIO, USA
68's are in front of the washer bottle and 69's are behind the fender tag, engine dosen't make a difference. Mike
This is starting to make more sense as I just found a photo a '68 Satellite from my archives that has it on the passenger's side. I think the larger fender mounting "pad" on the '69 models (see '69 above) would cover part of it if it was on the passenger's side, maybe that was the reason for the move? ![](/ubbthreads/images/graemlins/shruggy.gif)
(this is a '68 "G" St. Louis Satl.)
MikeR
[Re: A12]
#451115
08/28/09 01:12 PM
08/28/09 01:12 PM
A12
N.E. OHIO, USA
MikeR
Well at least on the Plymouth B-bodies it is much larger, the Dodge fender/rad support mounting "pad" is smaller than the Plymouth. Here is a '69 RR pad that you can see it covers more of the area where the label on the '68's was.
