Trouble with STRANGE Master cylinder
#451043
08/26/09 06:01 PM
08/26/09 06:01 PM
Posts: 1,416 Lake Charles,Louisiana
BILLYJAY
i have been trying to get my brakes to work properly on my new car.. using an aftermarket Strange unit with (Wilwood)disc/disc, no res.valve or port. valve either..i have bleed them over and over again and get some pedal but have to pump at least 1 or 2twice to get a decent pedal..anyone having issues or can shed some light on this??? thanks...
Re: Trouble with STRANGE Master cylinder
[Re: BILLYJAY]
#451044
08/26/09 06:04 PM
08/26/09 06:04 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Hate to mention it , but you probably got leaks in the system.
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: TS3303]
#451046
08/26/09 07:03 PM
08/26/09 07:03 PM
Posts: 3,456 Out West
408strokerdart
Out West
My guess is you didn't bench bleed it and it has trapped air in the bore. You will never be able to get all the air out bleeding through the calipers. The pedal is night and day different after bench bleeding.
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: 408strokerdart]
#451047
08/26/09 07:22 PM
08/26/09 07:22 PM
X 3 you need to get all the air out of the master cylinder 1st,
#451048
08/26/09 07:24 PM
08/26/09 07:24 PM
BILLYJAY
Ok, so how do you bench bleed ??? i'm Game.. i'm gonna need them at 150+mph...
Post deleted by Defbob
[Re: BILLYJAY]
#451049
08/26/09 08:10 PM
08/26/09 08:10 PM
#451050
08/26/09 08:17 PM
08/26/09 08:17 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
find some clear rubber hose that will barely slide onto the threaded portion of the fittings,
I got some spare brake line,,with fittings,,,and cut them,,,bent them,,thread them in,,,to bleed the MC,,,, fitting's keep it nice and tight,,,no air.
[Re: BILLYJAY]
#451051
08/26/09 08:31 PM
08/26/09 08:31 PM
Posts: 2,567 Appalachia
RedRam
Appalachia
Google "bench bleeding master cylinder" and you will find a boat load of articles with pics that show what Dave and Doc are describing. A you tube video was also listed in the results of a search. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: RedRam]
#451052
08/26/09 08:55 PM
08/26/09 08:55 PM
BILLYJAY
so after i bleed the master cylinder is it ok to empty or does it need to keep the fluid in it during reinstallation??? i think i can bleed it where it is if all i need to do is rereun tubing in each section and pump til the air is gone.. once the air is gone how does it stay gone when i remove the tubing and reattach my brake lines???
[Re: BILLYJAY]
#451058
08/26/09 10:26 PM
08/26/09 10:26 PM
[Re: WilliamHall]
#451061
08/27/09 04:41 PM
08/27/09 04:41 PM
Posts: 4,617 In the tower
RonTheAnnouncer
In the tower
I hope this works for you. I wanna see that car going down track. I really, really, really love that car. Absolutely my favorite Mopar, bar none! ![](/ubbthreads/images/graemlins/drool5.gif)
Ron H. "Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
