stupid 2 barrel carb question #450862
08/26/09 02:15 PM
08/26/09 02:15 PM
North Central Florida
E
eightlitermopar Offline OP
E
1969 dodge coronet 4 door
318 with a carter BBD 2 barrel
The car was lacking power under high RPM/Full throttle and slighly cut out like it was starving for fuel.
The carb had a "remanufactured" sticker on it from 2006, but the carb looked a lot older than that.
So, I got a rebuild kit to clean it up. I took it apart and cleaned it thouroghly, got A LOT of dirt crap out of the bowls.
Careful to put it back together.
Car starts fine, revs great in park/neutral. ON THE ROAD, Now it lacks EVEN MORE POWER from half throttle up and starts missing like it's starved for gas, but it doesn't actually die...
I should have left the dirty carb alone.
So what do I do now? Take it apart and reclean it?
Buy a new remanufactured carb?
Any ideas? It's little things like this that drive me crazy!
thanks
eight
Mopar or no car
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450863
08/26/09 02:23 PM
08/26/09 02:23 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Sometime they get rebuild some much they they have a internal problem.I have a few of them even rebuilt them on past owned cars .And took one of a parts car that worked great .But did you check your float level and snap in that retainer in to hold float down. leave any check balls out?What about fuel hoses at tank and at pump .Ive seen them swell the inside diameter down or split and suck air.Hows the fuel pump and pressure .And is it a new gas filter
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: stupid 2 barrel carb question [Re: WINGCARS_6970] #450864
08/26/09 03:15 PM
08/26/09 03:15 PM
Az
Crizila Offline
Crizila  Offline
Az
"Take it apart and reclean it."
Fastest 300
Re: stupid 2 barrel carb question [Re: Crizila] #450865
08/26/09 03:45 PM
08/26/09 03:45 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
You may want to try and find(borrow) a carb that you know is working properly and try it. Might not be the carb at all.
Re: stupid 2 barrel carb question [Re: repad] #450866
08/26/09 05:57 PM
08/26/09 05:57 PM
Fortworth TX
mod5v Offline
mod5v  Offline
Fortworth TX
If it had that much "crud" in it you possibly have a rusty tank and or fuel lines. Replace The Fuel Filter or even double up on one for a while.
Re: stupid 2 barrel carb question [Re: mod5v] #450867
08/26/09 07:40 PM
08/26/09 07:40 PM
E
E
I have two fuel filters, even before this rebuild.
There is one before and after the pump. The one after the pump is new within the last 500 miles.
I have a feeling that it may be the floats, but to be honest I didn't really mess with them. I have no idea it would run so crappy even after I just cleaned out/regasketed the carb.
Both check balls are in place according to size (double checked).
I thought giving a good clean and new guts could only improve performance...I guess I am learning as I go?
thanks for the input guys!
eight
Mopar or no car
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450868
08/26/09 07:49 PM
08/26/09 07:49 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
How many years since tank or sending unit has been checked? They can plug up a bit. (screen-sock on sender).
Re: stupid 2 barrel carb question [Re: buildanother] #450869
08/26/09 07:53 PM
08/26/09 07:53 PM
TX , NJ , FL
W
W
TX , NJ , FL
You can get a rag and compressed air and slowly enter very slight pressure into the fuel opening .With fuel line off at fuel pump.And see how it looks and how it flows out.If you get hardly anything time to drop the tank
Re: stupid 2 barrel carb question [Re: WINGCARS_6970] #450870
08/26/09 07:57 PM
08/26/09 07:57 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I had two filters on my car when I first got it running.. Read somewhere( I think the edelbrock site) that the inline filters are not designed to be in front of the pump as it could suck some of the paper element into the pump and ruin it... Mine only has one on it now....
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450871
08/26/09 08:16 PM
08/26/09 08:16 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
Just an opinion.I never liked the Carter 2 barrel carbs, their 4 barrel offerings however are great.If it were mine and I've done it before I would ditch it at the earliest opportunity.If you want a 2 barrel fit a 350 Holley or even a Rochester(some simple mods will be required).Or give that teen what IT REALLY WANTS...a good dual plane intake and 600 cfm vac Holley,Carter or edelbrock carb.
Re: stupid 2 barrel carb question [Re: solidcam] #450872
08/26/09 08:31 PM
08/26/09 08:31 PM
TX , NJ , FL
W
W
TX , NJ , FL
I tried to get away from that carb a few times .And get the holley replacement economaster never could find any
Re: stupid 2 barrel carb question [Re: WINGCARS_6970] #450873
08/26/09 08:57 PM
08/26/09 08:57 PM
E
E
thanks for the replies guys.
I know there are a lot of things I could do at this point. I am not ready to start dumping lots of money into this motor.
I may just end up throwing a 4 barrel on it, but then I have my exhaust to mess with etc...
Once I get the ball rolling with car projects, it is really hard to get it to stop.
I'll try another cleaning and thorough inspection... if that doesn't do it, it may be time for some bigger and better upgrades instead of tinkering with the little 2bbl.
any more thoughts?
eight
Mopar or no car
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450874
08/26/09 09:15 PM
08/26/09 09:15 PM
New Zealand
solidcam Offline
solidcam  Offline
New Zealand
I am not saying throw heaps of money at it.Look at a wreckers or whatever means you have available to source a second hand intake(virtually any alloy dual plane 4 barrel is going to be an improvement and will allow a 4 barrel carb).A Holley square bore vac sec should be dirt cheap second hand and kits and tuning for those carbs are everwhere.I have to be resourceful living in New Zealand(parts can be hard to come buy and expensive)You live in the States;you should be swimming in options for low-bucks....best of luck however you go.Exhaust is not an issue at the moment for you;concentrate on the carb issue thats where your power will come from...The exhaust wont hold you back any..
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450875
08/27/09 05:26 AM
08/27/09 05:26 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
As a tech my advice is this-
1) You first need to verify that your fuel pressure is not dropping off the face of the earth under load. A cheap gauge taped to the winshield during a road test will tell you lots.
2) Make sure ignition is up to snuff too.
Re: stupid 2 barrel carb question [Re: gdonovan] #450876
08/27/09 11:05 AM
08/27/09 11:05 AM
P
Paul_Fancsali Offline
P
Check the fuel line near the floor I had a police car that was sucking air threw porosity in the line changed the hose back at the tank and problem solved As stated check your fuel pressure but be careful air will pressurize and possibly give you a false reading if you pump is good Also on that model carb check your metering rods they can be set wrong and causing some of that problem. It is easy to work on carb so why ditch it? one ;last thing if you are reading over 20-21 inches of vacuum its too lean and hence part of your problem
Re: stupid 2 barrel carb question [Re: Paul_Fancsali] #450877
08/27/09 02:06 PM
08/27/09 02:06 PM
E
E
thanks for the input. I will mess with it some this weekend.
I will first check the fuel pressure and carb vaccumn, last I checked several months ago it was at 17-18 pounds of vacumn.
As far as the metering rods go...I just put them back in the way they came out...so I don't imagine it could be something like that.
I'll keep you posted. I am also going to ditch the double filter and just run one good one after the pump and see if that helps.
thanks.!
eight
Mopar or no car
Re: stupid 2 barrel carb question [Re: eightlitermopar] #450878
08/27/09 02:56 PM
08/27/09 02:56 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
There is little to no adjustment on the metering rods on a '69BBD. Maybe none. I can check later when I am out in the shop, I have a couple torn apart.
You didn't check your float height from what I read. Start there.
If the inlet turns while attaching the fuel line it will alter the float height, it doesn't take much.
They are great little carbs. Very-very simple!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: stupid 2 barrel carb question [Re: Rug_Trucker] #450879
08/27/09 04:50 PM
08/27/09 04:50 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I don't understand the bum rap some folks give them, I have worked on many in my 25+ years of wrenching.
The one I just pulled off my '74 worked flawless hot or old, much better than the 625 cfm 4 bbl that is on now.
Re: stupid 2 barrel carb question [Re: gdonovan] #450880
08/27/09 08:35 PM
08/27/09 08:35 PM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
You still haven't told us the condition of the tank filter. Does the car run OK from a dead stop when you floor it? If there is a supply problem, the motor should run fine for a few seconds, until the bowl runs low/dry. I've had sending units that looked like someone painted it with brown paint, and the tube needed a drill bit to clean it out.
