a-body carpet #450288
08/26/09 12:09 AM
08/26/09 12:09 AM
southern illinois
O
ozz383 Offline OP
ozz383  Offline OP
O
southern illinois
how much of the carpet was glued on a 71 demon and where mine looks original but went to remove and it is glued more than i thought it should be it is even glued along both side to the wiring harness covers. this is one of the last places i had to look for a build sheet but i think it has already been removed thanks for any info ozz
Re: a-body carpet [Re: ozz383] #450289
08/26/09 01:58 PM
08/26/09 01:58 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Every car I have pulled the original carpet out of had NO glue.
Re: a-body carpet [Re: Jim_Lusk] #450290
08/26/09 02:18 PM
08/26/09 02:18 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I know mine is the vinyl flooring, but none of it was glued, either.
Re: a-body carpet [Re: sharpie] #450291
08/26/09 02:48 PM
08/26/09 02:48 PM
Lyons, CO
MileHighDart Offline
Lyons, CO
mine was glued by a previous owner the first time the carpet was replaced. He glued the entire thing. Made the carpet very hard to remove for me. And I spent hours with a couple bottles of "goof off" to clean all the glue off the floor.
When I installed my new carpet I just glued around the edges by the door openings.
Re: a-body carpet [Re: Jim_Lusk] #450292
08/26/09 02:49 PM
08/26/09 02:49 PM
Central IL
70Sbird Offline
70Sbird  Offline
Central IL
I've had 4 71 Demon's and a host of other old Mopar's. I have never seen original glued carpet. I do not believe that the factory ever glued down the floor carpeting.
Scott
