Best spark plug for a small block Mopar #450171
08/25/09 10:51 PM
08/25/09 10:51 PM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
I know there has been some discussion about Big Block Spark Plug choices.
How about Small Block Spark Plug Choices.
Id like to hear everyones opinions on spark plugs for both Stock Engnes and performance applications.
I have always been the type to run what Ma Mopar put in the cars from the factory. So my choice is Champion RN14YC (405) for the stock 360 in my 72 Fury Wagon. I also used to run them in a 67 B body I had with a mild cam,Eddy intake and Holley 600 Carb.I never tried anything else,this plug choice worked fine for me and thats why I choose them.
Thats my preference. What does everyone else like to run and what results do you get that help you make the choice?
Re: Best spark plug for a small block Mopar [Re: SPWC] #450172
08/25/09 10:55 PM
08/25/09 10:55 PM
I have autolites (I forget the #) in my daily driver 318 & they are holding up good but that may be due to the mixture being good (think I just got lucky on that )
Re: Best spark plug for a small block Mopar [Re: SPWC] #450173
08/25/09 10:57 PM
08/25/09 10:57 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Don't know about "best", but Autolite 66 has been fine for me. Inexpensive, and no failures in my 90,000 miles in a daily-driver old stock '72 318. 230,000 original miles on the engine, and still have a nice golden brown on the plugs when I last replaced them.
Re: Best spark plug for a small block Mopar [Re: RapidRobert] #450174
08/25/09 11:07 PM
08/25/09 11:07 PM
SPWC Offline OP
SPWC  Offline OP
My 72 Fury wagon had Autolite 65 plugs in it and I probably would have kept them(If it aint broke,dont fix it) but #5 had a problem. The little cone shaped piece that goes around the center electrode came off and closed the gap on that plug when it was installed.So that plug wouldnt fire,otherwise they looked good. I now have fresh Champions and new Wires and it runs beautifully.
Re: Best spark plug for a small block Mopar [Re: SPWC] #450175
08/25/09 11:49 PM
08/25/09 11:49 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I used to run Autolite 65's in my 360 and 318s.
That was back in the good old days of USA stuff. Can't vouch for them now.
I want my fair share
Re: Best spark plug for a small block Mopar [Re: SPWC] #450176
08/26/09 12:08 AM
08/26/09 12:08 AM
MNobody Offline
MNobody  Offline
I run Autolite 64's in my warmed over 318.
Re: Best spark plug for a small block Mopar [Re: MNobody] #450177
08/26/09 02:55 AM
08/26/09 02:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have ran 3 different brands in my warmed up 340
Champions
Autolites were not to bad
Bosch Platnums best I have ever ran
I am truckless..
Re: Best spark plug for a small block Mopar [Re: 340SHORTY] #450178
08/26/09 03:51 AM
08/26/09 03:51 AM
Autolite 3924's...champions
Re: Best spark plug for a small block Mopar #450179
08/26/09 06:44 AM
08/26/09 06:44 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
champion RN12YC's are what I've run. never had a problem. on my motorcycle, it ran much smoother with champions than it did with bosch platinums.
2017 Grand Cherokee Overland
Re: Best spark plug for a small block Mopar [Re: patrick] #450180
08/26/09 08:09 AM
08/26/09 08:09 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We ran Autolite in all the older SBs.Ive only seen 1 car in 25 years that ran decent with Bosch plugs.I cant count how many sets of those I had to toss because they were junk.Rocky
Chrysler Firepower
Re: Best spark plug for a small block Mopar [Re: SPWC] #450181
08/26/09 09:17 AM
08/26/09 09:17 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The 12 to 14 heat range Champion plugs factory installed on the Chrysler small blocks were chosen to improve the emissions on the 'cold start' portion of the EPA test.
A Champion heat range of 9 to 10 is probably more suitable for performance and wide open throttle.
Do a search for
Magnum Engine Sparkplug FAQ
for a long listing of modern spark plugs
It is worth reading up on 'fine wire tip' spark plugs with irridium alloy for their pluses and minuses.
It is my personal experience that
choosing a gap on the larger side, (0.45 to 0.65)
and indexing the ground electrode strap so that it does not block the growth of the flame toward the center of the exhaust valve
both have small but worthwhile effects for faster burn
.... but I advise against using copper washers for indexing because they allow the plug to come loose.
Re: Best spark plug for a small block Mopar [Re: 360view] #450182
08/26/09 10:13 AM
08/26/09 10:13 AM
Az
Crizila Offline
Crizila  Offline
Az
I've been using NGK ZFR5F ( stock #7558 ) in my 408 mag heads for a year or so. Gap them at .050". They seem to color good and I like the extended cores as I think it improves the flame front. Had a couple of failures with the wire core plugs in the past and won't be using them again.
Fastest 300
Re: Best spark plug for a small block Mopar [Re: Crizila] #450183
08/26/09 11:18 AM
08/26/09 11:18 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I have never run anything but Champion. I wouldnt run a set of Bosch plugs if they were free
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Best spark plug for a small block Mopar [Re: 69L78Nova] #450184
08/26/09 11:30 AM
08/26/09 11:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
11 sec I agree.In fact Id pay to get rid of the Bosch.Like I said in 25 years Ive seen one car ryn decent with them.Even their 5 buck each plugs dont run well.I use Champions in all the newer Mopars.Just like the Autolites in the old ones.Ive been wanting to try NGKs in the Alumimun headed 440 though.Rocky
Chrysler Firepower
Re: Best spark plug for a small block Mopar [Re: 69L78Nova] #450185
08/26/09 11:56 AM
08/26/09 11:56 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I run Champions in everything and haven't had a problem. All teh Mopar guys in town do. Including the Hemi Dart and Hemi 'Cuda. Have run Champions for Almost 50 years.
I run RN11YC's or N9Y's if I can find them in the Duster and 12's in the warm street. Champions are a product of Federal Mogul
Re: Best spark plug for a small block Mopar [Re: MoparforLife] #450186
08/26/09 02:35 PM
08/26/09 02:35 PM
scratchnfotraction Offline
2x on the autolight 65 plugs,been running them for yrs and no probs
back in the day it was the champ RN12YC,had some luck with them,but did swap up to the AL65 plugs
boush platnums are junk,at least all I have run are...
Re: Best spark plug for a small block Mopar [Re: scratchnfotraction] #450187
08/27/09 05:14 PM
08/27/09 05:14 PM
Tampa, Florida
Road Ronin Offline
Road Ronin  Offline
Tampa, Florida
I was surprised to see such loyalty to Champion and Autolite, what with all the improved electrode designs on the market, now. I'd be interested in a dyno comparison, if anybody has one.
I was also surprised at the rejection of Bosch plugs outright, by a couple members.
I would rather avoid Bosch because it's foreign made and owned, but out of desperation, I bought a set of the expensive "Platinum 4X1"s or whatever they're called, in an attempt to improve the abysmal fuel mileage of my work van. The design seemed to be conducive to a more complete burn, I thought. Though I wouldn't call them "junk" or even "bad" in this application, I also saw no improvement in fuel efficiency.
Has anyone tried Splitfires or E3s? I'll probably never buy E3s as long as there's at least one brand NOT manufactured in Red China, but I'm curious what advantage, if any, there is in the design.
Leslie will lose; your automobile will lose; I WILL WIN! I shall build the greatest automobile in the world and I will win! Fate the Magnificent! MUAHAHAHAHAHA!!!
Re: Best spark plug for a small block Mopar [Re: Road Ronin] #450188
08/27/09 05:39 PM
08/27/09 05:39 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Tried Bosch in my 360 and it never ran right. Put autolite 64`s back in and never looked back.
Re: Best spark plug for a small block Mopar [Re: Road Ronin] #450189
08/27/09 05:39 PM
08/27/09 05:39 PM
Milano, Italia
FK5 Offline
FK5  Offline
Milano, Italia
I wouldn't look at plugs to increase my fuel economy. For plugs I'm looking for reliability - ability to resist fouling. I hear good things about NGK, but had a lot of trouble with them fouling on my dirt bike, so I always avoid them.
Re: Best spark plug for a small block Mopar [Re: FK5] #450190
08/27/09 08:25 PM
08/27/09 08:25 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
I run NGK #7's in my 340 and have run NGK's for a few years now. I like them and they seem to hold up well
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
